First post, by twiz11
Failed to finalize installation
Reply 2 of 9, by liqmat
twiz11 wrote on 2025-04-30, 22:11:
Just sift through the GOG forums and you will find your answer. Installs fine on my Windows 10 machine using the offline installer. Only other thing you have to do is set the resolution to 640x480 in the Syberia.exe properties. Fires right up. All in the GOG forums.
The attachment 640x480.png is no longer available
Reply 3 of 9, by twiz11
liqmat wrote on 2025-05-01, 00:54:
thanks ill try that, i also reached out to gog though not sure what they can do for me
Reply 4 of 9, by BEEN_Nath_58
Could be a corrupted installer?
Reply 5 of 9, by DosFreak
twiz11 wrote on 2025-05-01, 13:42:
They can receive a ticket, work the ticket with the user that submitted it. It's not difficult. If is then they need to close up shop.
Make your games work offline
Reply 6 of 9, by liqmat
cool man. let us know how it turned out.
Reply 7 of 9, by Dancsi40
they can help you out with the problem, they sell the game, so they should help you. They have a ticket system, just open one with the problem + screenshot and you will get an answer pretty fast.
Reply 8 of 9, by mo_jundi
i have the same issue pls let me know if you found a resolution
