First post, by twiz11
Failed to finalize installation
If you bought it from GOG then GOG should support you.
twiz11 wrote on 2025-04-30, 22:11:Failed to finalize installation
Just sift through the GOG forums and you will find your answer. Installs fine on my Windows 10 machine using the offline installer. Only other thing you have to do is set the resolution to 640x480 in the Syberia.exe properties. Fires right up. All in the GOG forums.
liqmat wrote on 2025-05-01, 00:54:twiz11 wrote on 2025-04-30, 22:11:Failed to finalize installation
thanks ill try that, i also reached out to gog though not sure what they can do for me
Could be a corrupted installer?
twiz11 wrote on 2025-05-01, 13:42:liqmat wrote on 2025-05-01, 00:54:twiz11 wrote on 2025-04-30, 22:11:Failed to finalize installation
They can receive a ticket, work the ticket with the user that submitted it. It's not difficult. If is then they need to close up shop.
cool man. let us know how it turned out.
they can help you out with the problem, they sell the game, so they should help you. They have a ticket system, just open one with the problem + screenshot and you will get an answer pretty fast.
i have the same issue pls let me know if you found a resolution
Closed.
This is not a support forum for GOG provided games nor a all-in-one thread for non-op issues.
See post #2.
