Reply 441 of 459, by roytam1
I wonder if CPU-Z can tell if CPU is capable for executing CPUID instruction from its main window?
Reply 442 of 459, by dormcat
The newest version 2.10 can no longer be installed on 32-bit Windows XP (installer icon is different as well, along with a 59% larger size compared to 2.09); an error message "[path]\cpu-z_2.10-en.exe is not a valid Win32 application" pops out. It can be installed onto 32-bit Windows 7 and 10, however.
Reply 443 of 459, by Sphere478
dormcat wrote on 2024-07-14, 07:27:
Crap.
I think great efforts should be taken to keep cpu-z working on all platforms physically capable of running such a program, and even fringe systems. Basically, 386+
Sphere's PCB projects.
Reply 444 of 459, by soggi
Wasn't here for over two years...time flies... When I saw the last two posts from @dormcat and @Sphere478 I had to login again to write this post!
Back in February (20th) this year I noticed that the latest version of CPUID HWMonitor, version 1.53 (I always use and recommend the zipped versions), doesn't start anymore on WinXP SP3 and just give the weird error message "Die Anwendung wurde mit STRG+C unterbrochen" (German for "The application was interrupted with STRG+C"). So I decided to contact @CuPid directly, but he had no idea/solution.
When the latest CPU-Z version (2.10) was released on July 12th, I got the same error message. I contacted @CuPid again and he still had no idea. After some exchange of information this time he finally found the reason! It was an API call which works on WinXP x64 and later, but not on WinXP x86 - I guess this is a Kernel 5.1 <-> 5.2 thing.
Long story short:
HWMonitor recently (July 17th) has been released in version 1.54 which works again on WinXP, surely @CuPid will also release a working CPU-Z version soon.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 446 of 459, by soggi
CPU-Z 2.11 has been released by @CuPid and it works flawlessly on WinXP SP3 -> https://www.cpuid.com/softwares/cpu-z.html.
Hopefully the new microcode revision report in "Mainboard" tab / BIOS also will find its way into the Vintage Edition of CPU-Z - I'll contact @CuPid, i guess.
kind regards
soggi
Reply 447 of 459, by dormcat
soggi wrote on 2024-09-21, 14:58:
Unfortunately not in my cases: I've tried two WinXP builds but still receive "not a valid Win32 application" warnings.
Reply 448 of 459, by soggi
OK...above you're talking about an installer, maybe it's this? I don't give a damn on installers and always use the zipped version and the cpuz_x32.exe from the .zip works flawlessly on WinXP SP3 - as said above. The system is POSReady "hacked" and has all updates until April 2019 installed, but I don't think this makes any difference.
On the screenshot below you can see it works on our IBM/Lenovo ThinkPad T60.
kind regards
soggi
Reply 449 of 459, by dormcat
soggi wrote on 2024-09-21, 22:48:
Ah, yes, so it was indeed the new installer of 2.10 and 2.11 causing problems. Problem solved; thanks a lot!
Reply 450 of 459, by soggi
You're welcome!
dormcat wrote on 2024-09-21, 23:45:
...so it was indeed the new installer of 2.10 and 2.11 causing problems
That's not right...version 2.10 actually didn't run on WinXP as described in my post above, independently of the problem with the installer! CPU-Z 2.10 used a function (RegGetValue) which is available on WinXP x64 and up but not on WinXP 32 bit, this has been resolved.
@CuPid will keep up the support of older Windows versions as long as possible.
But such installers are programmed by others, f.e. WinSCP uses InnoSetup which doesn't support WinXP anymore, but the program itself still supports it and you also have to use the zipped (portable) version of it - BTW there also was an issue with WinXP, but Martin Přikryl (the main developer) fixed it after my request.
In conclusion it's always a good idea to contact the developer(s) via e-mail (or some other channel), if you have problems with their program and of course it's also a good idea to donate some bucks to the developers of such free / open source tools (I did so to both).
kind regards
soggi
Reply 452 of 459, by bakemono
The main release of CPU-Z seems to have had a regression at some point: (screenshots from AMD Kaveri CPU on A88X chipset)
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 453 of 459, by elianda
I have an issue with CPU-Z Vintage that I am unable to the validate the results and it returns this error message:
file.php?mode=view&id=212661
System is NexGen Nx586-P90 on Win95 OSR2, CPU-Z Vintage 1.04.
Youtube Channel
Reply 454 of 459, by BetaC
elianda wrote on 2025-02-19, 13:19:
I have an issue with CPU-Z Vintage that I am unable to the validate the results and it returns this error message: […]
I am getting the same issue with multiple processors, including a genuine Intel DX-2/66 that's old enough to not be properly displayed.
Reply 455 of 459, by elianda
My suspicion is that this happens when there is a CPU that does not have a CPU-ID instruction.
Youtube Channel
Reply 456 of 459, by BetaC
elianda wrote on 2025-04-25, 02:00:
Actually, it might be something deeper than that, as I was able to generate and get accepted validations from 1.03. It did reject the 486, but that's as expected.
https://valid.x86.fr/x3r479
https://valid.x86.fr/weyi9b
Reply 457 of 459, by GigAHerZ
AFAIK, there isn't much information you can read from 486 and older CPUs. The parameters can only be detected from the system configuration. That means that you don't really get information about what CPU you have, but as what CPU you have your motherboard configured.
You could take Am486-100 CPU and run it with 2x33MHz speed and set the L1 cache to Write-Through and the software would be incapable to detect that this is not 486DX2-66 and is really a Am486-100. (In case of Am5x86, there's double L1 cache size, so software could start assuming some parts based on that)
I might be wrong. This is based on behavior of multiple software that i've used. Mostly SpeedSys - this is the most straight forward - i change the jumpers on motherboard and it shows a different CPU model.
Reply 458 of 459, by debs3759
GigAHerZ wrote on 2025-04-28, 07:26:
You are partly right. Without CPUID it is much harder to detect exactly what CPU you have in protected mode. In real mode DOS however, there are tests you can perform to detect most early CPUs. A 486 DX2 and a DX4 at 2c clock speed will appear the same, but even with an 8086 or earlier, there are tests you can perform to tell the difference between various (not all) makes and types.
Reply 459 of 459, by red-ray
The stepping is 0xB1 and even if it wasn't an Overdrive it should be mxB1/xB1. The reported speed is also wrong both HWiNFO and SIV report around 199.6 MHz.
file.php?id=218461
I also tried the CPU-Z Vintage Edition on my vintage PowerPC and feel it should do better.
file.php?id=224710
