Reply 60 of 78, by Mondodimotori
- Member
Joseph_Joestar wrote on 2025-04-03, 12:04:Not always. GOG sometimes makes changes to the executable which prevent it from running on WinXP since its (unmodified) kernel l […]
SScorpio wrote on 2025-04-03, 11:53:Most times you can run the installer and then just copy the files. You might need to delete DLLs that are wrappers for the newer systems.
Not always. GOG sometimes makes changes to the executable which prevent it from running on WinXP since its (unmodified) kernel lacks the needed functionality.
Quake 2 is one such example. The GOG version of the game will simply error out under WinXP, while working fine on Win10. And that one isn't even on the "preservation" list yet.
Sombrero wrote on 2025-04-03, 11:55:But yeah, one should still expect the very real possibility that games on that program might not install on pre-Win10 systems, wouldn't be surprised if the vast majority are like that and quite frankly I think it sucks ass.
Sadly, it's not the first time they did this.
I remember watching an older video from Phil where he showed how to extract the ISO image from the (old) GOG version of Indiana Jones and the Fate of Atlantis. You could then burn that image to a disc, and play it on real DOS hardware. In Phil's video, GOG was still shipping the game with DOSBox, so that was a relatively easy process. But when I bought the game a few years back, GOG had switched to ScummVM, which made the procedure no longer possible.
I've checked and they claim to offer a "rollback" feature via the Galaxy client, letting you donwload older patches of games, but it's based on the devs or publishers not unpublishing any previous updates Gonna check on the client when I get back home, but I'll get back on the dedicated thread on this forum, wich you linked before.
