Reply 700 of 709, by superfury
After some more improvements, Windows 9x seems to run fine with it.
So does DOOM (and DOOM II). Although those ran before already.
Running test-sbp.exe somehow makes it run into a ARPL instruction that keeps faulting to itself when selecting the DSP audio test?
It could be HIMEM.SYS though.
Edit: Nope. Without HIMEM.SYS it still happens.
It's actually executing an ARPL instruction somehow.
Edit: It literally crashes on that instruction after sending a DSP Enable Speaker command. Either that or the executable is somehow corrupted during the installation process.
UniPCemu Git repository
