First post, by douglasfir
Hey guys, I am trying to install 512MB of RAM in this board, I have 2x matched Kingston 256MB/133MHz/ECC DIMMs, pulled from a working system. No matter what slot the DIMMS are in, the system only sees 256MB, it doesn't matter which DIMM i use either. The board apparently supports ECC memory, there is a setting in the BIOS i changed to indicate the ECC memory is present as well. I have cleaned the DIMMs contacts, as well as the DIMM sockets contacts with 99% alcohol, no change. Is there a setting in the BIOS that could need to be changed? possibly a BIOS update? what say you? The system has a Pentium 3 500/512 CPU in case anyone was wondering. Thanks for your help.
Reply 1 of 3, by tauro
I remember mixing and matching DIMMs for a SY-6BA+III because it only supported certain combinations of modules simultaneously (and in a specific order too).
I'd suggest getting other DIMMs and trying different slots and combinations.
Reply 2 of 3, by Repo Man11
Sounds as though you're running into the 440BX memory density issue; here is a thread that should help you find memory modules that will work properly. Can anyone help me find the correct type of RAM? Asus CUBX 440bx
Reply 3 of 3, by douglasfir
Tauro, Repo Man11, thank you very much for your help, It indeed appears I need to try "lower density" DIMMs without buffer/parity chips. Not a big deal really. I really appreciate it 😀
