Reply 40 of 49, by ElectroSoldier
- Oldbie
Ozzuneoj wrote on 2025-05-28, 21:17:A 6200 will be faster than an FX 5500 for sure, but any of these GPUs are going to be massively underpowered for games made afte […]
rezamolaee wrote on 2025-05-27, 14:12:Thank you everyone for your help, I decided to buy a GA-8I865GME-775-RH, equipped it when 2GB of DDR memory, it support Core 2 Duo in revision 3.9, this board is more convenient than older ones and I'm going to be sure system always be bottlenecked by GPU.
however I have another question, is GeForce 6200 worth buying if you have FX 5500?A 6200 will be faster than an FX 5500 for sure, but any of these GPUs are going to be massively underpowered for games made after 2000 or 2001 unless you're okay with low settings.
If you've got one of the most capable AGP boards ever made, you really should try to find some at least mid range if not high end AGP cards.
Something like a 6800\GS\GT would probably be a decent fit, or if you're trying to keep the budget down a Radeon 9600 Pro or 9600 XT will be significantly faster than any of the others you've mentioned.
Yeah but going by my experience of both cards the 6200 can be a bit of a problem in Windows 98.
I have one that uses a 6200 no problem at all (GX270)
I have a T5720 that doesnt seem to like to load the drivers that I use on my GX270 without a problem, then I have a Shuttle PC that doesnt like them at all either and I have a Asrock 775i65G based system that doesnt mind working at all with the same card and drivers that wont work in the Shuttle PC.
But the FX5500 works in any and all of them so I really cant recommend the 6200 for Windows 98 at all.
If you dont want DX9, which the OP doesnt than a GeForce4 Ti of any flavour will out perform a 6200 and work every single time.
The 6200 is one of those cards that is better best forgotten.
