Table Fog & 8-bit Paletted Textures
Reply 620 of 648, by BEEN_Nath_58
marxveix wrote on 2025-05-15, 10:14:
BEEN_Nath_58 wrote on 2025-05-15, 10:08:
marxveix wrote on 2025-05-15, 09:43:
Does it have fog? It has paletted textures for sure.
The graphics settings has a Fog option
I have seen rain, but no fog, maybe its because i have used ATi cards Rage Pro and Rage128 Pro.
I see only resolutions + use 8bit textures support and use triple buffer option.
Its not in the initial Config.exe. It is inside the Main Menu settings
Reply 621 of 648, by Elixium
In AI prompt sessions I've been seeing conflicting info about support for these features, do the GF3 Ti xxx and the GF4 Ti 4xxx cards have full support?
I've been seeing that the FX5200 and FX5500 don't have the full hardware and that the 8bit texture is instead done via software emulation and requires you to swap back and forth between different driver versions for different games and the results might not be perfect due to it being emulation. Also any cards that are more powerful than the FX5500 do not have any support at all e.g. the FX5800.
Reply 622 of 648, by Kahenraz
As far as I'm aware, there is support up to and including the FX series for both table fog and 8-bit paletted textures. Table fog has always been emulated on NVIDIA cards, spotty on ATI, and fully supported without emulation on 3dfx.
Reply 623 of 648, by BEEN_Nath_58
How do you know if table fog is getting emulated?
Reply 624 of 648, by Kahenraz
NVIDIA released a whitepaper demonstrating their use of vertex fog instead of table fog. Vertex fog is not as accurate as table fog, as mentioned specifically in the whitepaper.
https://developer.download.nvidia.com/assets/ … v/docs/Fog2.pdf
The drivers also explicitly stated that it's emulated (vertex) table fog.
Reply 625 of 648, by Joseph_Joestar
Kahenraz wrote on 2025-05-23, 15:50:
This only applies to Nvidia cards released before the original GeForce. Relevant bit from the linked document, around page 10:
Nvidia wrote:
The RIVA 128, RIVA128ZX and the RIVA TNT all emulate table fog using vertex based fog. The GeForce 256 supports table fog in hardware.
They did leave the emulation option in the drivers though, not sure why. Possibly as a fallback/compatibility setting. Also, if you look at table fog comparison screenshots between Nvidia and 3DFX cards, the visuals are practically identical, save for the (unrelated) differences in 16-bit dithering.
file.php?id=117957&mode=view
file.php?id=117959&mode=view
file.php?id=141009&mode=view
My retro builds
Reply 626 of 648, by BEEN_Nath_58
Could it be that the option was placed as a temporary hold for the bugged hardware implementation? Table fog works and is supported in Hardware to date, but they mess up the vector coordinates due to which it becomes invisible. They haven't fixed it yet for some reason.
Reply 627 of 648, by Kahenraz
It kind of blows my mind that something as important to early graphics accelerators for both visuals and performance, such as fog, was neither consistent nor perfected as a staple feature across manufacturers. I also wish that 16-bit dithering was given better treatment by ATI; something that NVIDIA did very well, even as far back as the RIVA.
Reply 628 of 648, by Joseph_Joestar
Kahenraz wrote on 2025-05-27, 03:29:
Starting with the original GeForce, Nvidia cards supported table fog in hardware. Matrox G400/G500 cards also had hardware support for table fog, per their respective datasheets.
As for ATi, I don't know what they used for table fog emulation, but it looks accurate on R300 and R400 cards when using Catalyst 7.11 and newer.
file.php?id=132012&mode=view
My retro builds
Reply 629 of 648, by Kahenraz
Support from ATI was very inconsistent for contemporary cards and their drivers. I also hate ATI's dithering, which only has options for ordered dithering or noise.
To be fair, all of this was new technology, and it was also ATI's introduction to 3D accelerators. They also had to keep pace with how fast technology was moving, and it wasn't always economical for them to put time into older chips, when they always needed to support whatever new features were coming out for the next series. I just feel that a lot of potential for some of these older chips were left on the table.
Reply 630 of 648, by eddman
While looking to see what's the highest OpenGL version supported by Geforce 4 Ti, found this nvidia PDF. It lists the supported texture formats in detail for up to Geforce 6.
https://http.download.nvidia.com/developer/Op … ure_formats.pdf
EDIT:
A newer one that covers up to Geforce 200.
https://developer.download.nvidia.com/opengl/ … ure_formats.pdf
Reply 631 of 648, by Joseph_Joestar
eddman wrote on 2025-06-03, 11:39:
Nice find!
Those documents officially confirm what we've previously seen from in-game testing. Meaning, that support for EXT_paletted_texture was dropped with the GeForce 6 series and above. And also that TNT and TNT2 cards didn't have that functionality.
My retro builds
Reply 632 of 648, by kolderman
Does anyone know if FX series did table fog in hardware or via emulation? I know gf2-4 did, but FX is not clear. Same with paletted textures.
Reply 633 of 648, by The Serpent Rider
Should be the same, since GeForce FX is an extension of the previous NV20(NV25) architecture.
Reply 634 of 648, by Joseph_Joestar
kolderman wrote on 2025-08-13, 01:23:
Hardware support for paletted textures on NV3x cards has been confirmed directly by an Nvidia engineer. See here for the actual reference. Similarly, table fog is supported in hardware since the original GeForce per this paper by Nvidia.
I don't know if they changed anything in the implementation between GeForce generations, but I couldn't find any visual differences when comparing my GeForce FX to my Voodoo 3. See here and here for comparison screenshots.
BTW, table fog still works fine on my GTX 980 Ti under WinXP. Note that anything after GeForce 7 lacks 16-bit dithering, so you'll get banding in games which only use 16-bit colors, but that's a different issue.
My retro builds
Reply 635 of 648, by kolderman
Thanks thats useful. But I thought table fog ended with FX series. Unless the emulation is what is doing it after FX.
Reply 636 of 648, by Joseph_Joestar
kolderman wrote on 2025-08-13, 11:04:
No, only paletted texture support was dropped from GeForce 6 onward. Table fog works just fine on all later Nvidia cards that are WinXP compatible. As to how fog rendering is handled under the hood, I have no idea. Visually, it looks the same on post FX cards, as can be seen in my GeForce 6 tests. Relevant screenshot:
file.php?id=123815&mode=view
My retro builds
Reply 637 of 648, by marxveix
Someone made good work about Rage128/Rage128Pro and Win9x drivers (table fog and palleted texture info is also there).
https://www.retrohardware-reviews.de/ati-rage … e-right-driver/
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 638 of 648, by Joseph_Joestar
marxveix wrote on 2025-09-26, 09:06:
These are some interesting findings.
It looks like table fog and paletted texture support on those cards depends on the driver version. I'll update the wiki with this info when time permits.
My retro builds
Reply 639 of 648, by Kahenraz
That's fabulous. So, there is a driver that supported turning off 16-bit dithering. That's my biggest complaint about ATI cards around this generation and later. Ordered/pattern dithering is just terrible. It's too bad that it's it's not possible to disable it on the later drivers.
