Reply 860 of 1009, by LSS10999
vsharun wrote on 2025-06-03, 08:24:In my case 200fc 300fc 1d 0f was enough for pgusinit and scream tracker. Also I may confirm scream tracker does not require any […]
Also I may confirm scream tracker does not require any DMA, coz it plays perfectly without LDRQ line connected. With LDRQ line connected on Asrock - scream tracker okay - everything else - loooooong init and no sound.I sent my whole bunch of Asus Z87/Z97 boards for soldering LDRQ1, may you please check
sudo lspci -vvv | grep -A20 'I/O ports'
on your Asus board, maybe important ports claimed by some other PCI device(s) - this may explain why we see no ISA PnP working.
This also may further explain why you may not bother for LPC whole range 300 FC decode, because important ports (VGA you mention earlier) are decoded earlier on PCIe.
I haven't checked Scream Tracker yet. The GUS mode itself works, just for some reasons it cannot detect any RAM and I don't think the soldering was the problem after inspecting with a magnifier. I even replaced the SPI PSRAM chip with another one yet the problem persists.
From what I can tell through the schematics the PSRAM only had connection with the Pico's GPIO pins that are being used for SPI, yet I'm not sure if there's a way to test the status of the communication between the Pico and PSRAM (as well as the PSRAM's integrity) without going through GUS protocols...
On the other hand, SB mode (and FM) works perfectly fine on that system when I tested it with DIGPAK's SETD/SETM.
