First post, by old school gamer man
So I'm going back and forth on the system I want to build. I always wanted a Ppro system and if I went that rout I would go with a Pii over drive. But I also always wanted to max out of K6-iii+ system too.
I know the sk8 system would lack SD ram and agp but that aside how to the two stack up ?
Thanks!
Reply 1 of 4, by PD2JK
PII Overdrive is 'only' 300/333MHz.
K6-III+ starts at 400 MHz for the embedded version. Yesterday I ran Speedsys with this processor in particular, overclocked a bit.
The attachment DSC_4514.JPG is no longer available
Reply 2 of 4, by old school gamer man
so the k6 is a tick faster ?
Reply 3 of 4, by douglar
old school gamer man wrote on 2025-06-11, 15:44:
A K6-III+ @ 550 should have :
  • a significant advantage on integer code for older games & general usage
  • a slight advantage in FPU performance for 3d games
  • a Super 7 platform that supports 100Mhz bus, SDRAM, AGP Graphics & UDMA storage
But a K6 @ 300 would be:
  • slightly slower at integer code
  • weaker FPU performance
  • on any of a wide variety of chipsets, 430FX through Super 7 so the platform can vary greatly, while the socket 8 boards were almost all in a pretty narrow range that had a 66Mhz bus, EDO RAM, PCI graphics & MWDMA storage
Reply 4 of 4, by BinaryDemon
I’d guess the K6-3 + would be decently faster.
On YouTube, there’s a comparison of a Tilamook overclocked to 420mhz compared to a standard K6-2 at 420mhz. Generally the K6-2 wins by about 15%, although most of those wins are synthetic tests. The actual game performance seems fairly close.
https://www.youtube.com/watch?v=fqB4yCssUCM
