First post, by Nooflebot
Been looking all over the place online and every time I've tried to order from websites they cancel my order because they don't actually have them in stock anymore /:
I specifically need the 2.8v version of these processors since the system I plan to pair these with is a silicon graphics visual workstation 540 and the motherboard / VRM's only support 1.3 - 3.5 voltage range CPU's.
The SKU for the 2.8v 900MHz Pentium III Xeon's is SL5D3 or SL4XY.
I'm trying to not spend a fortune on this as I need 4 of these CPU's to complete the system. Already had to spend a decent chunk of change on the specific VRM model that supports these CPU's.
Reply 1 of 3, by PD2JK
Can't help you with (only one) 700 MHz SL49P without any heatsink I guess?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 3, by red-ray
QAK9 should also work.
file.php?id=221511
Reply 3 of 3, by Nooflebot
I am still looking for these CPU's. I've only managed to source 1 out of the 4 I need because I got lucky with a eBay listing, they unfortunately did not have more.
