First post, by Nooflebot
Been looking all over the place online and every time I've tried to order from websites they cancel my order because they don't actually have them in stock anymore /:
I specifically need the 2.8v version of these processors since the system I plan to pair these with is a silicon graphics visual workstation 540 and the motherboard / VRM's only support 1.3 - 3.5 voltage range CPU's.
The SKU for the 2.8v 900MHz Pentium III Xeon's is SL5D3 or SL4XY.
I'm trying to not spend a fortune on this as I need 4 of these CPU's to complete the system. Already had to spend a decent chunk of change on the specific VRM model that supports these CPU's.
Reply 1 of 10, by PD2JK
Can't help you with (only one) 700 MHz SL49P without any heatsink I guess?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 10, by red-ray
QAK9 should also work.
file.php?id=221511
Reply 3 of 10, by Nooflebot
I am still looking for these CPU's. I've only managed to source 1 out of the 4 I need because I got lucky with a eBay listing, they unfortunately did not have more.
Reply 4 of 10, by Nooflebot
Update on this, now have 3 out of four 900MHz CPU's installed. If anybody has just one SL4XY they'd be willing to part ways with I'd be willing to pay a pretty penny for it. It would complete the CPU side of my SGI 540 Visual Workstation.
Endgame of what I'm aiming for:
- 4x 900MHz Pentium III Xeons (Currently 3/4)
- 2GB Proprietary SGI SDRAM (Accomplished)
- Sound Blaster Live! 5.1 Platinum (Can transplant from other machines)
- Some graphics card that works with the weird firmware of the SGI 540 (currently testing options)
- SD1100 Serial Digital Video Interface Card (One sold on eBay recently that I missed, I have a feeling I will be waiting a long time before I see another)
- Blu-ray optical drive with sata to IDE converter
- Internal Superdisk drive (saw some external SGI Superdisk drives on eBay that could be a good source for a internal drive colored black)
- SATA Raid controller (Finding something that is bootable will likely be extremely hard if not impossible so I might be stuck with SCSI / IDE)
- If the SATA Raid controller works out I want two SSD's in RAID0 for the system
- SGI Gigabit Ethernet Card
- SGI 1600SW or SGI CRT Monitor
- Accompanying USB SGI Keyboard and Mouse
Reply 5 of 10, by eisapc
Same problem here: I own 5 of the 2.8V 900MHz 2MB CPUs, but need a fourth sixth one to complete a HP Netserver currently running 6x 700 MHz 1MB.
I did not find a single affordable one during the last 10 years.
Reply 6 of 10, by Nooflebot
eisapc wrote on 2026-02-06, 11:51:
Same problem here: I own 5 of the 2.8V 900MHz 2MB CPUs, but need a fourth one to complete a HP Netserver currently running 6x 700 MHz 1MB.
Well if you ever want to part ways with one of the 900MHz 2.8v PIII Xeon's I'm able to do $250 since I really really want to finish my SGI 540's CPU's.
Reply 7 of 10, by luckybob
I haven't seen a positive hit on my ePay searches in YEARS.
I have four of them, but I want to build them into a Supermicro S2QR6 build. (I need a chassis for it)
Hells bells, i'm having trouble getting P-PRO OD chips for my 6x6 without spending $500 a chip.
I will go through my box of processors and check if I have a stray 900/100/2m/2.8 cpu.
Reply 8 of 10, by Jackhead
I remember reading that the SL4XY has a problem before production week 14 2000. Random freezes on CPU load. Anyone more about it?
Im trying to find the site again. Was from IBM a recall.
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus XG DLS 1x SL4XY - SG Voodoo 5 6000 PCI - 2GB RAM ECC- Audigy 2 ZS - MX300
Reply 9 of 10, by luckybob
First I've heard about it.
I know my chips are good, I ran them for years as a home router. 😀
Id be interested to see what you find.
Reply 10 of 10, by Jackhead
found it again:
https://www.ibm.com/support/pages/intel-penti … rce=chatgpt.com
