TgamesFR wrote on Today, 09:01:
Hi Joseph_Joestar,
Do you know if the MPU401 from the external gameport bracket of the Audigy 2 ZS is usable with external Midi synths on Windows 98 and DOS ?
It's been a while since I tested that, so take this with a grain of salt. From what I recall, external MIDI devices can be used for native Windows games and applications with an Audigy 2 ZS. So something like Windows Media Player or Final Fantasy 7 should work fine, as long as you select MPU-401 as the output in Control Panel.
But DOS games will automatically use the Audigy's internal synth, and cannot access the external MIDI device at all. This seems to be a hardcoded driver limitation. Some people have apparently found ways around this using some third-party utilities, but I have never tested that myself.
