Reply 57040 of 59086, by Jccwu
weedeewee wrote on 2025-06-18, 20:24:I clearly recall someone on vogons posting about making new metal brackets but I can't find the relevant post. Maybe someone e […]
Ozzuneoj wrote on 2025-06-18, 19:20:The lot arrived, and it doesn't look like it took any more damage. It was filthy, but it cleaned up nicely! I will test it out w […]
The lot arrived, and it doesn't look like it took any more damage. It was filthy, but it cleaned up nicely! I will test it out when I get some time (after straightening some pins and checking for shorts of course).
If it shows any signs of life at all I will recap the whole thing, replace the dented crystal and the broken plastic around the Sony connector. Then it will just be a matter of getting a bracket that fits it. Not sure if any other cards could act as donors, but that would be the preferred way since a GUS deserves a real metal back plate rather than something 3D printed.
Maybe someone else can shine a light on this.as for the gus max ram upgrade, you might be able to use some ram of a video card.
I've been cutting stainless steel strips on a laser machine for two years now 😀
there are already strips for more than 80 different boards
