Reply 29780 of 31028, by Ozzuneoj
Trashbytes wrote on 2025-06-23, 08:35:
Tested this 5900Xt that arrived today, it works just fine but I will need to find a solution for the fans, they work ok but the method used to hold them in the cooler was poorly designed so they are not held in that great. Might need to find a 3rd party cooler solution for it or find a method of fixing how the fans are held in the cooler.
The attachment FX5900Xt Front.jpg is no longer available
I always thought that design was pretty nice looking. There were lots of interesting coolers at this time but the fan setups were atrocious. At least on that one you can just take the cover off the top to get to the fans, unlike these stupid things that BFG, Chaintech, PNY and probably some others used:
The attachment bfg.5950.front.jpg is no longer available
The attachment bfg.5950.back.jpg is no longer available
The fans are so bad and the cooler is so horrible to work on that I would value a fully functional 5950 Ultra with good fans at about 1/5 the value of one of these:
The attachment 79-front-428711674.jpg is no longer available
I think a complete aftermarket cooling solution for those shiny dual fan turds is the best way to make them usable again. If someone wants to collect them with the original cooler style, they can have all the dead cards that were run too long with bad fans. There are thousands of them out there floating around (either FX series or 6000 series).
I'm so glad that cooling technology has improved as much as it has. The pre-7800GTX times were very dark indeed.
Reply 29781 of 31028, by Trashbytes
Ozzuneoj wrote on 2025-06-23, 14:25:
I always thought that design was pretty nice looking. There were lots of interesting coolers at this time but the fan setups wer […]
Decided to just grab a 3rd party cooler rather than try and mess with the original cooler, Ill keep the original incase I ever decide to sell the card in the future.
https://www.ebay.com/itm/305378882640
Went with one of these which should work pretty well as its designed for just the 5900XT.
Reply 29782 of 31028, by DarthSun
I think the Sparkle FX5900XT's cooler turned out pretty good, it's still quiet and efficient.
The attachment Csillogás.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 29783 of 31028, by Trashbytes
DarthSun wrote on 2025-06-23, 15:17:
Thats a much nicer cooler than the gainward one design wise.
Reply 29784 of 31028, by PcBytes
Mine uses some GOOFY AHH HUEG cooler that came off... a 9600Pro.
file.php?mode=view&id=222084
Yeah, I had no other coolers to use on it. Came from a scrapper in a GPU lot and was the only card to work without any issues.
Reply 29785 of 31028, by Trashbytes
Nicce flex with that Teratech card !
Nice cooler too bet it keeps that card cool.
Reply 29786 of 31028, by gmaverick2k
My FX5900XT is cooled by a new old stock cooler from a guy in ebay slovakia (retro_coolers). Nice and quiet.
Have it on the 'bench' checking out nglide 1.05 performance on a 775i65g system
file.php?mode=view&id=222085
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 29787 of 31028, by Alesia
Did two things today,
Attempted to test more on my Kaypro 10's no-post issue, disconnected everything from the board, different combos, double checked voltage from the power supply (completely on spec actually, 5.0, 11.9, -12.1) and all that jazz trying to get it to behave any differently and sadly nope, just the damn blinking cursor it's had since I got it.
Also tried to get Pools of Radiance running on my Hyundai Super 16 (Turbo) to no avail. Double checked my graphics settings and got everything set for color leading to a monochrome monitor and no dice, start disk works but then the overlay disk attempts to load and eventually gives up on blinking cursor. I am cursed to stare at blinking cursors. Also found out that Mode CO40 and Mode CO80 produce a "not supported by this machine" error when they are used. Not surprising tbh.
Thinking I might kick on my Vectra VE later and play a bit of Thunderscape since I downgraded it's drive to a 8gb instead of a 120gb (it can only handle under 8gb drives) and trashed my saves in the process.
Reply 29788 of 31028, by gmaverick2k
Trashbytes wrote on 2025-06-23, 14:43:
Decided to just grab a 3rd party cooler rather than try and mess with the original cooler, Ill keep the original incase I ever d […]
It's a very nice cooler, especially new. Really silent, no bearing noise
Reply 29789 of 31028, by PcBytes
gmaverick2k wrote on 2025-06-23, 15:40:
My FX5900XT is cooled by a new old stock cooler from a guy in ebay slovakia (retro_coolers). Nice and quiet. Have it on the 'ben […]
Yeah that's the same card as mine. I'll be on the lookout for a similar cooler or at least any FX5900 cooler that will keep it at bay.
Speaking of which, what's the RAM modules on yours? Mine seems to use Hynix.
Reply 29790 of 31028, by gmaverick2k
PcBytes wrote on 2025-06-23, 15:49:
Cant see the ram modules as they're covered by the cooler on the front. There aren't any ram modules on the back. The guy from slovakia ebay had a number of them for sale, new old stock when i purchased it in September last year (checked email invoice:
12.99 euros + 7.70 euros p&p + 4.14 euros tax = 24.83 euros shipped to the UK. I should've ordered more at the time, although its only deigned specifically to be used for this card only
Looks like he's out of stock.
Reply 29791 of 31028, by Trashbytes
I would tell you mine but both front and back memory ICs are under heat sinks, mine is a 256Mb card, its a Golden Sample too so it might even OC a bit once I get the new cooler on it.
Reply 29792 of 31028, by gmaverick2k
Need to find an elegant solution for my elsa gloria iii quadro 2 pro and Ti4200 which have a zalman heat sink with removednoisy fan and a chinese flower cooler with noisy fan. Currently got some quiet fractal design case fans strapped onto them using cable ties and powered using dupont wires
file.php?mode=view&id=222089
file.php?mode=view&id=222088
Reply 29793 of 31028, by Trashbytes
I would switch them out for some Noctua 40/50 mm fans, they are small and quiet.
Reply 29794 of 31028, by gmaverick2k
Also got reacquainted with using MS intellimouse 5 button optical usb 1.1 using a ps2 adapter. Forgot how awesome these mice are especially in win 98 with ps2rate upped to 100 Hz. Pet peeve was having to keep USB enabled on motherboard which would cause irq issues as I'm really fond of my wireless logitech m590 optical mouse. With this, I'm happy to use a PS/2 solution and have USB permanently off. have another used one spare. Used to use these a lot in the 2000's
Reply 29795 of 31028, by Trashbytes
Just scored a nice LE-1660 for my AM2 AGP setup, 2.8Ghz single core rocket !
its a low voltage CPU so perhaps I can convince it to run at 3Ghz with a few FSB tweaks .. not sure if the Biostar K8M800 will let me as its not designed for OCing.
Reply 29796 of 31028, by tehsiggi
I recently snacked a EPOX 9NDA3+ from ebay. It was listed as broken.
I was on the lookout for a good 939 AGP board and nForce3 was really nice to have.
So today I took care of it and got it working. Turns out we have an exploded polyfuse in the Firewire section - that's what I call irony!
I removed the burned part and cleaned everything. The PCI slot will need replacement if it is ought to look like new again at some point. But so far - the board works just fine and will be my primary testing platform from now on.
Here are some pictures of FireWire with burnout!
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 29797 of 31028, by gmaverick2k
tehsiggi wrote on 2025-06-23, 18:30:
I recently snacked a EPOX 9NDA3+ from ebay. It was listed as broken. […]
[pedantic] don't want to be that guy, but the correct terms are "snag" or "snagged", not "snack" or "snacked". [/pedantic] 😒
Reply 29798 of 31028, by Trashbytes
gmaverick2k wrote on 2025-06-23, 19:53:
I mean . .who are we to tell a retro collector they cant snack on their motherboards!
