Reply 280 of 307, by PatmanQC
PBA tour 2 For windows 11 absolute 100% does not work.
PatmanQC wrote on 2025-01-19, 15:24:PBA tour 2 For windows 11 absolute 100% does not work.
It is difficult to say: the game obviously is not fit since it causes rampant memory corruptions, and on your case it may have started sooner than later.
BEEN_Nath_58 wrote on 2025-01-19, 17:08:PatmanQC wrote on 2025-01-19, 15:24:PBA tour 2 For windows 11 absolute 100% does not work.
Nice jab
For Deus Ex and Rune, if you have audio issues or crashes, try using the DSOAL (DirectSound OpenAL) wrapper. Just drop dsound.dll and the config file into the game folder. This fixed sound and restored EAX effects for me.
Can confirm that Journeyman Projects 2 and 3 have severe issues on Windows 11 24h2
JMAN 2 was added to ScummVM though, so there are workarounds for the entire series except 3
"Dignity and an empty sack is worth the sack" 109th Rule of Acquisition
sentrywasbored wrote on 2025-06-23, 02:48:Can confirm that Journeyman Projects 2 and 3 have severe issues on Windows 11 24h2
What are the problems with Buried in time and windows 11 24h2 ?
willow wrote on 2025-06-23, 20:26:sentrywasbored wrote on 2025-06-23, 02:48:Can confirm that Journeyman Projects 2 and 3 have severe issues on Windows 11 24h2
BIT95 Launcher executable no longer works, workarounds are available through running BIT2432. Mainly an issue for GOG users as for some reason GOG still routes to BIT95 as a shortcut executable (presumably to accommodate 8 bit color users??) constant crashes and freezes during cutscenes, transitions, and dialogue
sentrywasbored wrote on 2025-06-23, 22:21:willow wrote on 2025-06-23, 20:26:sentrywasbored wrote on 2025-06-23, 02:48:Can confirm that Journeyman Projects 2 and 3 have severe issues on Windows 11 24h2
Have you tried software like ovtdvm ?
willow wrote on 2025-06-25, 16:39:sentrywasbored wrote on 2025-06-23, 22:21:willow wrote on 2025-06-23, 20:26:What are the problems with Buried in time and windows 11 24h2 ?
not a 16 bit executable, and regardless there is a scummvm engine for it so it's not a major issue (unless you're a gog user who wasn't told)
sentrywasbored wrote on 2025-06-27, 05:04:willow wrote on 2025-06-25, 16:39:sentrywasbored wrote on 2025-06-23, 22:21:BIT95 Launcher executable no longer works, workarounds are available through running BIT2432. Mainly an issue for GOG users as for some reason GOG still routes to BIT95 as a shortcut executable (presumably to accommodate 8 bit color users??) constant crashes and freezes during cutscenes, transitions, and dialogue
I have tried journeyman project 3 on windows 11 24h2. GAme launch and works except sound sttutering. I don't know why.
willow wrote on 2025-07-20, 20:10:sentrywasbored wrote on 2025-06-27, 05:04:willow wrote on 2025-06-25, 16:39:Have you tried software like ovtdvm ?
Did you fix the Sound?
Lukica1 wrote on 2025-08-19, 08:59:willow wrote on 2025-07-20, 20:10:sentrywasbored wrote on 2025-06-27, 05:04:not a 16 bit executable, and regardless there is a scummvm engine for it so it's not a major issue (unless you're a gog user who wasn't told)
Yes, I succeeded by downloading a new version of quicktime.qts (versions 4, 5, and 6 all work fine) and renaming it to QTFORJP3.DLL, which is the customized DLL used by the game and I replaced the old DLL with the new one.
willow wrote on 2025-08-19, 17:14:Lukica1 wrote on 2025-08-19, 08:59:willow wrote on 2025-07-20, 20:10:I have tried journeyman project 3 on windows 11 24h2. GAme launch and works except sound sttutering. I don't know why.
thankfully i can watch the cutscenes in Journeyman Project 3 using VLC even if i cant play the game anymore on modern systems
twiz11 wrote on 2025-08-19, 19:38:willow wrote on 2025-08-19, 17:14:Lukica1 wrote on 2025-08-19, 08:59:Did you fix the Sound?
with this change, Journeyman Project 3 cd french version works very well on modern systems like win11 and ryzen 3900x
What games was you playing or still paying?
Lukica1 wrote on 2025-08-20, 07:08:willow wrote on 2025-08-19, 17:14:Lukica1 wrote on 2025-08-19, 08:59:Did you fix the Sound?
2 and 3.
I've still got nowhere with the Volvo S40 racing. Motorhead works fine in Windows 10, sound-wise. But S40 Racing is a no-go, a small stutter sound that loops, sometimes.
I tried VMWare with Windows 98 and XP; 98 won't start and XP just black-screens (whether the CD-ROM version, the rip, and if using the 1.3 patch).
Are there any audio emualtors, as such? Like dgVoodoo2 for audio?
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
IndirectSound and DSOAL might feed some needs
Awesome thanks for that, I'd tried IndirectSound and got no difference, but DSOAL from https://github.com/kcat/dsoal/releases gets the sound back, finally!
Admittedly the menu and in-game sounds are pretty much identical to Motorhead, but it's great to have it making noise again!
