Reply 340 of 371, by MAZter
- Oldbie
Feipoa, I wondering if you ever heard about "TetrisMan's Benchmark" ?
MAZter wrote on 2025-06-27, 20:09:Feipoa, I wondering if you ever heard about "TetrisMan's Benchmark" ?
Never. Would be nice to see the results on some kind of chart.
Stesch wrote on 2025-06-20, 12:46:Thanks! I found an photo i've already taken with the CPU jumpers visible, so I made you a little graphic of the jumper settings […]
zuldan wrote on 2025-06-20, 10:18:Thank you so much! […]
Stesch wrote on 2025-06-20, 10:09:Hi, of course, when I'm back home, I will take a photo of the cpu jumper block (jp16-22). You can see my benchmarks of the combo a few posts earlier in this thread, including Quake. With a 44,52Mhz FSB (Cyrix running @134Mhz), I get 21.5 FPS in Quake. With the stock 14.318Mhz crystal and a 40Mhz FSB, I get 17.2 FPS
Thank you so much!
Is that with Quake v1.06 or v1.08?I should have just scrolled up! V1.06. Some nice scores!
Thank you! CPU is working.
zuldan wrote on 2025-06-29, 08:37:Stesch wrote on 2025-06-20, 12:46:Thanks! I found an photo i've already taken with the CPU jumpers visible, so I made you a little graphic of the jumper settings […]
Nice, good to hear! Do you have your L2 cache in WT or WB mode? If you want to use it in WB mode, make sure the dirty tag bit is working properly. So far I haven't had a motherboard with a SIS85C471 chipset where this has worked out of the box...
crayon eater (but only the tasty ones)
Stesch wrote on 2025-06-30, 06:18:zuldan wrote on 2025-06-29, 08:37:Stesch wrote on 2025-06-20, 12:46:Thanks! I found an photo i've already taken with the CPU jumpers visible, so I made you a little graphic of the jumper settings […]
WB mode with the dirty bit is working out of the box 😉 Some screenshots without Cyrix enhancements enabled.
zuldan wrote on 2025-07-02, 09:28:WB mode with the dirty bit is working out of the box ;-) Some screenshots without Cyrix enhancements enabled. […]
Stesch wrote on 2025-06-30, 06:18:zuldan wrote on 2025-06-29, 08:37:Thank you! CPU is working.
Nice, lucky you! Next step is 1024KB l2 cache 😁
Guys,
The 486 computer is like an American funny Car dragsters.
You build it for optimal performance and push it to its limits.
You take a single cylinder engine and push it to its limits
It’s like a lawn mower engine.
This reminds of when I was a kid we use to build mini bike motor cycles and go carts
Out of lawn mover engines and race them on a dirt track and push them to the limits.
It was a lot of fun and we learn how to build them from scratch.
Stesch wrote on 2025-07-02, 14:03:zuldan wrote on 2025-07-02, 09:28:WB mode with the dirty bit is working out of the box ;-) Some screenshots without Cyrix enhancements enabled. […]
Stesch wrote on 2025-06-30, 06:18:Nice, good to hear! Do you have your L2 cache in WT or WB mode? If you want to use it in WB mode, make sure the dirty tag bit is working properly. So far I haven't had a motherboard with a SIS85C471 chipset where this has worked out of the box...
1024KB installed
zuldan wrote on 2025-09-03, 10:09:1024KB installed
Very nice! Now I'm out of ideas what you could upgraded next 😁
zuldan wrote on 2025-09-03, 10:09:1024KB installed […]
Stesch wrote on 2025-07-02, 14:03:zuldan wrote on 2025-07-02, 09:28:WB mode with the dirty bit is working out of the box 😉 Some screenshots without Cyrix enhancements enabled.
1024KB installed
Swell banks o' cache!
@Intel486dx33 - quite the fitting analogy.
My newly-find CxDX4-100 with green heatsink at SMT terminator with ALi chipset. Best memory timings of 0 waitstates and 2-1-1-1 cache timing.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
There's a tool, Dukemark for MS-DOS, that evaluates system performance in Duke3D and displays the final results on the screen after the benchmark is complete.
https://www.moddb.com/games/duke-nukem-3d/dow … mark-for-ms-dos
https://www.youtube.com/watch?v=QIA39N--tT8
It's great for testing 486 builds.
That would be useful. Duke Nukem 3D is far more interesting of a game for the period of hardware I prefer to test. My kids really enjoy Duke Nukem, but aren't into DOOM at all.
I decided to test this out since I have my socket 3 setup in the livingroom.
A Cyrix 5x86 (S1R3) running at 45.5*3, or 136.5 MHz, 1024K cache, MB-8433UUD.
ISA sound is enabled; game resolution at 640x480; detail high....
Bench1: 17 fps ave
Bench2: 20 fps ave
Bench3: 17 fps ave (max 36, min 9)
BTB, FP_FAST, LSSER, MEM_BYP, DTE_EN all set to optimal.
The game is perfectly playable on this system, but I've never been spoiled by high frame rates on any video game.
A database of benchmark results for this timedemo would be helpful. Obviously, I'd need to rebench with sound disabled.
feipoa wrote on 2026-07-24, 08:01:A database of benchmark results for this timedemo would be helpful.
What you're saying is "bring out your socket 3 systems"? 😎
yeah. I have always wanted a Duke Nukem timedemo for 486 class systems. The 320x200 values put the results between Quake and DOOM, but much closer to DOOM.
I ran it with sound disabled this time. Same system: Cyrix 5x86 (S1R3) at 45.5*3 = 136.5 MHz, 1024K cache, 64 MB EDO, MB-8433UUD motherboard.
dukemark.exe /bqbench1
dukemark.exe /bqbench2
dukemark.exe /bqbench3
320x200
Bench1: 52 fps average (23 fps min, 96 fps max)
Bench2: 58 fps average (34 fps min, 106 fps max)
Bench3: 53 fps average (29 fps min, 120 fps max)
640x480
Bench1: 19 fps average (11 fps min, 34 fps max) ----------> 17 fps with ISA sound
Bench2: 21 fps average (11 fps min, 34 fps max)
Bench3: 19 fps average (10 fps min, 36 fps max)
800x600
Bench1: 13 fps average (8 fps min, 22 fps max)
Great find! I’ll try benching my rigs this weekend.
Got it. Will being out my 486SOM system when returning from vacation. Unfortunately it's SiS496/497 based, so results won't be fully comparable to your initial tests. But it will give some idea of the individual differences on a handful of CPUs. I have Intel from sx16 to dx4-100 both WT and WB at hand, couple of AMD 133s and a POD83 which unfortunately only runs 83 and not 100
Once I get my lab usable again, i have a, 3x50MHz Am5x86, 1024kB Write-Back cache, and Trio32 VLB graphics card, machine to try this out.
It's my "fastest true 486 machine", which by my definition is strictly without PCI bus.
I wasn't sure where to post this finding, but since the OP benchmark results were plagued with the M919's automatic PCI frequency adjustments as a function of FSB, I thought I'd post it here.
I recently discovered that if I run the M919 with a 45 MHz FSB, the PCI bus stays at 45 MHz, rather than being reduced to 2/3*45, or 30 MHz by the BIOS. This is because the M919 BIOS lookup table identifies the CPU as a Cyrix 5x86-133 and doesn't use the FSB as verification.
For information on how to run a 45 MHz FSB, refer to this post Re: Branch Prediction on the Cyrix 5x86 S1R3 This is probably the simplest and most stable approach to running a Cyrix 5x86 at 135 MHz. Instead of using the push-button oscillator, you can use a standard 45.000 MHz DIP crystal oscillator.
