The Ultimate 486 Benchmark Comparison
Reply 340 of 345, by MAZter
Feipoa, I wondering if you ever heard about "TetrisMan's Benchmark" ?
Reply 341 of 345, by feipoa
MAZter wrote on 2025-06-27, 20:09:
Never. Would be nice to see the results on some kind of chart.
Reply 342 of 345, by zuldan
Stesch wrote on 2025-06-20, 12:46:
Thanks! I found an photo i've already taken with the CPU jumpers visible, so I made you a little graphic of the jumper settings […]
zuldan wrote on 2025-06-20, 10:18:
Thank you so much! […]
Stesch wrote on 2025-06-20, 10:09:
Hi, of course, when I'm back home, I will take a photo of the cpu jumper block (jp16-22). You can see my benchmarks of the combo a few posts earlier in this thread, including Quake. With a 44,52Mhz FSB (Cyrix running @134Mhz), I get 21.5 FPS in Quake. With the stock 14.318Mhz crystal and a 40Mhz FSB, I get 17.2 FPS
Thank you so much!
Is that with Quake v1.06 or v1.08?
I should have just scrolled up! V1.06. Some nice scores!
Thank you! CPU is working.
Reply 343 of 345, by Stesch
zuldan wrote on 2025-06-29, 08:37:
Thank you so much!
Nice, good to hear! Do you have your L2 cache in WT or WB mode? If you want to use it in WB mode, make sure the dirty tag bit is working properly. So far I haven't had a motherboard with a SIS85C471 chipset where this has worked out of the box...
crayon eater (but only the tasty ones)
Reply 344 of 345, by zuldan
Stesch wrote on 2025-06-30, 06:18:
WB mode with the dirty bit is working out of the box 😉 Some screenshots without Cyrix enhancements enabled.
The attachment 120_Speedsys.JPG is no longer available
The attachment 120_CTCM.JPG is no longer available
Reply 345 of 345, by Stesch
zuldan wrote on 2025-07-02, 09:28:
WB mode with the dirty bit is working out of the box ;-) Some screenshots without Cyrix enhancements enabled. […]
Nice, lucky you! Next step is 1024KB l2 cache 😁
