RAM chips layout on Quadro 980 XGL
Reply 20 of 25, by myne
Induction? Absolutely not.
Might as well be asking if you should microwave it.
I built:
Reply 21 of 25, by tehsiggi
Things that come in mind:
Regular oven + thermocouple for measurement of actual temperature
Upside down steam iron (without steam of course) in a vice + some ceramic standoffs between the iron and the board + some thermocouple for measurement of actual temperature.
There are also cheap hot plates available from your friendly neighbourhood chinese seller. Not exactly meant for pre-heating, but they do the job.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 22 of 25, by myne
I already suggested a regular oven +casserole dish ~100c.
It didn't have to be exact. Just less than the ~120c tolerance of the plastic and rated operating temp of most caps.
The delta temperature should be around 250 then instead of 330.
I built:
Reply 23 of 25, by bimole
Of course, not with the GPU!
Just to heat a ''thermal mass''.
What about heating the whole PCB with a big heat gun from a big distance (let's say 30-40cm)?
Reply 24 of 25, by myne
Airfrier without the box?
Sure. You can do some chips first to test
I built:
Reply 25 of 25, by dm-
you can get a "phone pre-heater" on aliexpress, something like 10-15$ and the size is exactly fit the video card.
it will pre-heat the card up to 150c. controlled temperature.
The attachment preheater.jpg is no longer available
