Another PS/2 Mouse ISA (ISA8) card adapter
Reply 300 of 316, by feipoa
Depending on the 3rd party IC-only supplier you choose, you can specify "new, original only" for the IC's and I have had good luck with this. When asked, they will often say if the part is or isn't new/original.
When I check the IC support list on my TL866II Plus, I see no mention of the EPM3064 or the ATF1504. http://www.xgecu.com/MiniPro/TL866II_List.txt
Similarly, when I check the support list on my Wellon VP-390, it also doesn't mention mention support for the EPM3064 or the ATF 1504. http://www.weilei.com/VP-390list.htm
As such, I am guessing that you used the TL866 to programme only the ATMEGA8A, then used the FT232H to programme the ATF1504? Can we order the ATF1504 pre-programmed? I recall seeing some of these options when ordering parts from Digikey.
Indeed, the HASL PCB's might reduce interest. If I ever have time for this, I'm going with gold contacts. The bracket can be mickeymoused if you don't have a 3D printer. This project is fairly low on my priority list because I already have two of the Rio444 original units, but could use another unit for my testbed. I was hoping that by the time I'm more eager for another one of these ISA cards, that the war in Ukraine will be over and I can merely order another adaptor from Rio444.
Reply 301 of 316, by maxtherabbit
feipoa wrote on 2025-06-28, 05:06:
Correct, that's why I had to use JTAG
Yes they do offer it for the ATF1504. I don't know what they charge for this service or whether a MOQ applies however.
Who's interest 🤣? I ordered a prototype run of 5 for me and me alone. I have zero interest in ever manufacturing assembled cards for sale to others, and I didn't want to dump any money into this before I was sure it would work.
I did sell 2/5 of the bare, unassembled PCBs to other members here at cost but that was offered only out of courtesy and I warned them about the substandard surface treatment.
Reply 302 of 316, by feipoa
I mean, the HASL PCB's might have less interest for people requesting your left-over bare PCB's compared to if those PCB's were ENIG. That's all I was saying. It's really not important. If I ever get around to this project, I wouldn't mind assembling extras for members for direct donations to charity. Same applies for any extras I've assembled.
Reply 303 of 316, by maxtherabbit
WRT the mounting bracket:
If someone with more CAD experience than me could take a mechanical drawing of a regular keystone slot bracket and overlay the circle cuts from Rio444's image included with the firmware package to make a STEP, DXF or EPS file then anyone who wants one could just send the file to send cut send and get individual parts or short runs really cheap.
Come to think of it keystone might already have a step file available for the blank bracket. I'll check some EDA sites later
Reply 304 of 316, by maxtherabbit
They do indeed!
Is there anyone here who could amend the attached STEP file with the three drilled holes shown in the attached image?
Reply 305 of 316, by Yoghoo
maxtherabbit wrote on 2025-07-02, 13:45:
They do indeed!
Made a quick stl file. Not test printed it so don't know how it will fit. If you need a step file you can convert it online if you search for stl to step.
Reply 306 of 316, by maxtherabbit
Yoghoo wrote on 2025-07-02, 16:18:
They do indeed!
Thanks! I'll print one off to test fitment, but ultimately I'd like to get one made of sheet metal by send cut send.
Reply 307 of 316, by Yoghoo
maxtherabbit wrote on 2025-07-02, 17:03:
They do indeed!
You're welcome. I love functional 3D prints especially for my retro hobby but to be honest for this one I would just take a spare metal bracket and slowly drill 3 holes in it. 😀
Reply 308 of 316, by keropi
haven't heard anything back from Rio444 , sent an email 4 days ago
I also read that some trouble was in that area because of the war so this is somewhat alarming - I hope it is nothing in the end
Reply 309 of 316, by maxtherabbit
Yoghoo wrote on 2025-07-02, 17:11:
You're welcome to, personally I don't trust that I could achieve the level of quality or precision I'd want using hand tools.
Are you able to export a STEP directly from whatever software you used to create the STL file? The STL printed fine but I've tried two online converters and neither would produce output that send cut send's website can parse.
The original STEP file works fine with their website, so I'm pretty sure the conversion is the issue
Reply 310 of 316, by maxtherabbit
I printed a prototype of the bracket in PLA and it seems to fit perfectly, though at the original thickness it's far too flimsy to use obviously. I share a building with a dental lab who has a resin printer so we might try making a run of them out of resin.
Reply 311 of 316, by Yoghoo
maxtherabbit wrote on 2025-07-02, 18:18:
Good to hear. Normally I design it from scratch and then it's easier to add some support here and there to make it more sturdier. Just making the whole bracket thicker is most of the times not a good solution as that will cause other issues (like not fitting in case or PS/2 connector not fitting well).
maxtherabbit wrote on 2025-07-02, 17:48:
I just opened the STEP file in Bambu Studio and saved it as an STL. After that edited it in Tinkercad and saved it. For a small 'project' like this that's faster for me then using Onshape or so.
Reply 312 of 316, by maxtherabbit
Yep I also know from experience that making them thicker isn't a great option. Plastic is just a poor material for slot brackets, simple as
Reply 313 of 316, by Guld
I was thinking of trying to get blanks that work and seeing if a machine job would be willing to do a small run. No idea what that would cost but I'll look into it when I get a chance.
Reply 314 of 316, by Guld
Alright, I was able to follow maxtherabbit's instructions and get a board working! I did install the LED, no issues there.
Followed all his instructions and the only thing that threw me off was the make sure the FT232H is set to "I2C mode off" on the switch on the FT232H itself.
Have not tested all the different settings, but default COM1 settings and ctmouse detected the mouse wheel, which is nice.
Thanks for the write up!
Reply 315 of 316, by Rio444
You'd better use PETg, it's strong enough.
Reply 316 of 316, by maxtherabbit
Here is an STL flie of the slot bracket (w/hole) combined with the mounting tabs. I printed a prototype from PLA and it's not very strong, but good enough for me to use. Perhaps PETG would be better as Rio suggests.
