Reply 57100 of 59262, by Masterchief79
bestemor wrote on 2025-07-01, 17:07:Masterchief79 wrote on 2025-06-29, 20:12:Glad you like It <3 The marketing was wild. They even promoted the rounded corners of the board as a feature and designed a logo […]
Ozzuneoj wrote on 2025-06-28, 20:46:Wow, what a crazy board! Lots of questionable early-2000s marketing stuff silk screened on there! Like, what is Dual Channel DDR 999 DIMM? Or PCI Extreme?
All the colorful board lighting is impressive too. This has to be one of the first motherboards with purely cosmetic lighting built in. I have honestly never seen anything like it from that time period.
Such a cool board. And with a 4800+ too! Nice find!
Glad you like It <3
The marketing was wild. They even promoted the rounded corners of the board as a feature and designed a logo for it. 😁The 4800+ is average at best and tops out at about 2650MHz@1.5V. But no matter.
Last pic with my only purple GFX.I also scored a bundle containing a MSI 848P, 3GHz Northwood (30 cap EE reject), 2x1GB Mem, and most importantly, a working Radeon 9800XXL. The CPU had some bent pins, but I got it working again. Tops out at 3.65GHz@1.625V on my ABIT IC7G.
How did you make that Noctua cooler fit on the 478 socket ??
Which model is it ?
I didn't, it's mounted by gravity 😁
Should be an NHD-14 which absolutely does not fit on 478 boards of you try and mount it properly.
For a quick OC Test this is always great though.
