Reply 57100 of 59867, by Masterchief79
bestemor wrote on 2025-07-01, 17:07:
Masterchief79 wrote on 2025-06-29, 20:12:
Glad you like It <3 The marketing was wild. They even promoted the rounded corners of the board as a feature and designed a logo […]
Ozzuneoj wrote on 2025-06-28, 20:46:
Wow, what a crazy board! Lots of questionable early-2000s marketing stuff silk screened on there! Like, what is Dual Channel DDR 999 DIMM? Or PCI Extreme?
All the colorful board lighting is impressive too. This has to be one of the first motherboards with purely cosmetic lighting built in. I have honestly never seen anything like it from that time period.
Such a cool board. And with a 4800+ too! Nice find!
Glad you like It <3
The marketing was wild. They even promoted the rounded corners of the board as a feature and designed a logo for it. 😁
The 4800+ is average at best and tops out at about 2650MHz@1.5V. But no matter.
Last pic with my only purple GFX.
The attachment IMG_20250629_144802413.jpg is no longer available
I also scored a bundle containing a MSI 848P, 3GHz Northwood (30 cap EE reject), 2x1GB Mem, and most importantly, a working Radeon 9800XXL. The CPU had some bent pins, but I got it working again. Tops out at 3.65GHz@1.625V on my ABIT IC7G.
The attachment IMG_20250629_141123356.jpg is no longer available
The attachment IMG_20250629_144852173.jpg is no longer available
The attachment IMG_20250627_143825608.jpg is no longer available
The attachment IMG_20250627_142936073.jpg is no longer available
How did you make that Noctua cooler fit on the 478 socket ??
Which model is it ?
I didn't, it's mounted by gravity 😁
Should be an NHD-14 which absolutely does not fit on 478 boards of you try and mount it properly.
For a quick OC Test this is always great though.
Reply 57101 of 59867, by bestemor
Masterchief79 wrote on 2025-07-02, 19:23:
I didn't, it's mounted by gravity :D Should be an NHD-14 which absolutely does not fit on 478 boards of you try and mount it pro […]
Glad you like It <3
Which model is it ?
Haha! 😆
Ok, as I really did wonder about that, and looked up Noctua coolers for socket 478, and actually FOUND a SINGLE one they had, but nowhere to be found for sale:
https://ncc.noctua.at/cpus/model/Pentium-4-420
The super rare and special wonder of https://noctua.at/en/nh-u12 !
The attachment Noctua NH-U12 for socket 478-mounting parts.jpg is no longer available
Reply 57102 of 59867, by A001
Many modern coolers' mounting brackets are really rather simple to modify (mutilate) to fit 478 as long as there is sufficient space around the socket. LGA115x and LGA1200 have 75mm x 75mm mounting hole spacing while S478 is 59,44mm x 76,2mm I believe. Just a few additional holes to the bracket can be all that's needed.
Reply 57103 of 59867, by Susanin79
Bought this cool monitor: Nokia 447X092.
Unfortunately, it died right during the demonstration the seller was giving me. The picture collapsed into a single vertical, noisy, white blinking stripe, and some magic smoke appeared inside the monitor.
The seller was very kind, so I ended up taking the monitor for free. I’ll try to disassemble it, see what may have caused the issue, and attempt to repair it.
Reply 57104 of 59867, by ChrisK
Any hopes for this one?
The attachment 2025-07-03-14-06-12-756.jpg is no longer available
Bought it already some time ago for only a handfull of coins, but put it aside right after delivery and seeing it's main feature (wasn't visible in the advertisement pics):
The attachment 2025-07-03-14-06-21-729.jpg is no longer available
Not sure how that could happen and also not how to fix it. Haven't powered it on yet but pretty sure it won't live up with a smile...
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 57105 of 59867, by Trashbytes
ChrisK wrote on 2025-07-03, 12:16:
Any hopes for this one? […]
Oof that's not great, that's how you let the angry pixies out.
Reply 57106 of 59867, by PcBytes
Oof.... pretty much RIP, unless you're inclined to reball a new one and drop it there (heck, probably an 693A would work too.)
Reply 57107 of 59867, by ChrisK
Yea, not sure about my microsoldering skills to reattach those traces. Well ... no.
OTOH, desoldering of such big chips from boards with huge planes isn't easy-going, too. *#!+*
Following the picture on theretroweb there must have been a heatsink. That would explain this kind of damage. Still a wild performance doing this without leaving ANY other traces of brute force.
Guess I'll put it back in it's box.
Reply 57108 of 59867, by BitWrangler
Susanin79 wrote on 2025-07-03, 11:23:
My wild guess would be horizontal output transistor... probably because of tired caps... so maybe a half dozen or so components to replace. Make sure anything you are assured is "equivalent" can handle the amps.
Reply 57109 of 59867, by PcBytes
ChrisK wrote on 2025-07-03, 13:12:
Yea, not sure about my microsoldering skills to reattach those traces. Well ... no. OTOH, desoldering of such big chips from boa […]
What I suggested involved a reballing machine and a replacement 693A chip. No way anyone would be able to fix that chip as is.
Reply 57110 of 59867, by Kahenraz
I'm not sure if it broke the solder balls from beneath, but it does look like it tore the vias from above.
Reply 57111 of 59867, by luckybob
Oh yea, you don't get that kind of ball removal without a lot of tearing.
Id use hot air to remove the chip and get a sit-rep of what's going on underneath. You might be extremely lucky and not have significant pad/via damage.
Reply 57112 of 59867, by PD2JK
A while back I bought an HP Kayak XU 7/550. Upon inspecting I was in for an unpleasant surprise cause there was an XA (single processor) board fitted.
I really wanted to restore the system so this unit came in. Banana P3B-F for scale.
The attachment DSC_4881.JPG is no longer available
(retention clips where packed separately, thumbs up for the seller)
has all kinds of stuff
Reply 57113 of 59867, by chrismes
A shop on ebay Germany is currently selling these Siemens ID Mice for 11€ plus shipping. They are faulty and should have never been sold. Still, I had to have one.
Some info in German:
https://www.spiegel.de/netzwelt/web/siemens-w … s-a-261864.html
Edit: Google translation of this page:
https://www-spiegel-de.translate.goog/netzwel … &_x_tr_pto=wapp
Mine is a version 2.0.
Reply 57114 of 59867, by Susanin79
BitWrangler wrote on 2025-07-03, 15:01:
Did a first visual inspection yesterday, see details here. Once the main PCB was cleaned, I found two burned resistors: R195 and R205. All other components look fine — no leaky capacitors or other visibly damaged elements. Will check the nearby transistors for sure.
Reply 57115 of 59867, by ChrisK
PcBytes wrote on 2025-07-03, 18:39:
I know, I know. Just dreamin'... 😉
Do you think a 693A would be possible with regards to BIOS etc.?
The balls itself should be ok as far as can be seen. It's mainly the most upper layer of the package that was lifted.
Reply 57116 of 59867, by Living
Oh the Humanity!
Reply 57117 of 59867, by chrismes
chrismes wrote on 2025-07-04, 10:17:
A shop on ebay Germany is currently selling these Siemens ID Mice for 11€ plus shipping. They are faulty and should have never b […]
I just performed a quick test on my IBM 380XD with Windows 98 SE and this thing actually works as a mouse and as a finger print sensor.
Reply 57118 of 59867, by Nexxen
ChrisK wrote on 2025-07-04, 10:51:
Push it down with a finger and turn it on.
Worst case it doesn't POST, best, it works only when pushed down.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 57119 of 59867, by Lostdotfish
Bought this a few days ago for £29
The attachment Screenshot 2025-07-04 123552.png is no longer available
Pretty immaculate looking DFI Pentium 4 board... nice!
The attachment Screenshot 2025-07-04 123648.png is no longer available
Hang on a minute... what's that..?
The attachment Screenshot 2025-07-04 123748.png is no longer available
The attachment Screenshot 2025-07-04 123830.png is no longer available
