Reply 60 of 92, by PC@LIVE
I saw Phil's latest YouTube video, and it was just talking about the latest version of this program, well I have a number of PCs where I can try it, some have K6-2 CXT with multi 6X (i430TX/VX), others instead use FSB 95-100, and they are K6-III and K6-2+, but surely the performance for some is not the best, because for example, I forced a K6-2 CXT at 400 on a MB that sees it as K6-300, probably all the improvements of the CXT are ignored.
Then I read something 😨 in the previous messages, which I didn't quite understand, we're talking about a multi 6.5X, here I know the maximum is 6X, but having a 433 CPU in my collection, I have doubts that it was planned with FSB 66 and multi 6.5X, instead of the strange 96.2 with which it was put on the market.
I'll see if I can do some tests with the latest program, I currently have an M550 with a K6-233 on the bench, I don't know if I would have any improvement with that CPU, but I can easily upgrade with other K6-2, up to 400 - 450 MHz, beyond that I could get to 500 but I would have the PCI over 41 MHz, and I wouldn't want to have problems in the future for this.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 61 of 92, by analog_programmer
PC@LIVE, there's no such thing as x 6.5 multiplier on (s)s.7 platforms. I'm not sure if K6 family CPUs officially support x 6 multiplier (as they use x 2 multiplier motherboard's settings for it). K6-2 at 433 MHz (427.5 MHz ??) seems like weird thing, but can be achieved on some ss.7 chipsets through some weird bus frequencies using x 5 or x 5.5 multipliers. K6INIT actually provides x 2 multiplier for CXT core K6-2 (or newer K6-III, K6-2+/III+) CPUs, but I can't recall now if I successfully tried x 1.5 and x 1 multi through this software tool. If you have an working (s)s.7 system with K6-II CTX or newer K6 family CPU, just test these multipliers and give some feedback 😉
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 62 of 92, by PC@LIVE
analog_programmer wrote on 2025-01-13, 15:46:
Yes ok thanks ☺️
As for the multi 6.5X, I thought that AMD had actually designed them, and maybe 🤔 they gave up stopping at 6X, maybe they could be useful on MB with FSB 66 (or 75 83 Max), a bit like the K6-2 333, which can be used with both FSB 95 and 66, so for example the 433, it could ideally work at both 96.2 and 66 (having the multi 6.5X).
Maybe 🤔 they thought it was easier to go up with the FSB, rather than with the multi, but strangely they stopped at 100 MHz, even if the latest motherboards, it seems that there are two or three models (or a little more), did not have L2 cache on the MB, since it had now been inserted in the CPU with the K6+ versions.
I'll try the multi you suggested (1X or 1.5X), I hope 🤞 they work, I could run the CXT from 75 MHz up 🔝, it depends on whether the MB allows FSB from 50 or what would be the minimum, let's say that I converted most of the S.7 cards to AMD, while the older ones with minimum voltages of 3.3V (VCORE), I have them with Intel and Cyrix and AMD K5.
I hope 🤞 to have news by the weekend, and bring you good news 📰
Reply 63 of 92, by mrdjey
Geoman wrote on 2025-01-13, 10:12:
IBM Aptiva 2168 / AMD K6 III+ ATZ / IBM PC DOS 7.0 gives me, while using DEVICE=K6INIT.EXE /auto in config.sys […]
Keep C fatal error: Unable to fixup segment references
running as an executable works, though I get a partial error:
ERROR | You are trying to configure too many MTRRs, maximum is 2!
ERROR | PCI/AGP FB detection failed! Skipping...
ERROR | Preparing automatic configuration
SUMMARY | some actions failed
after that, the computer locks up.
i tried K6INIT for the first time yesterday on a K6-2+ 570 running PC-DOS 7.1 but it just freezes my system without giving any output 🙁
AMD K6-2+ 570ACZ | Aopen AX59 Pro | 3DFX Voodoo 3 2000 | AWE32
Reply 64 of 92, by mrdjey
i was able to run K6INIT if i don't load EMM386, so i put it in my CONFIG.SYS before the EMM386 line, and that seems to work and it got me +20 FPS in Quake benchmark.
but still not able to run if from the command line to make cache of multiplier adjustments.
Reply 65 of 92, by Oerg866
Hello,
with EMM running it is not possible to run a lot of these priviledged CPU instructions, that's why I wrote it in a way that you can load it from CONFIG.SYS... If anyone with low level DOS systems programming knowledge can chip in - it may be possible to thunk those instructions out to some real mode code, much like how BIOS calls are wrapped; otherwise it is not possble and the crash is expected (I could maybe add detection for it to make it more graceful)
It's the same reason the program doesn't run from within Windows...
Best
Eric
Reply 66 of 92, by Oerg866
SteveC wrote on 2025-01-03, 14:05:
Just tried this on my Aptiva K6-2 450 and it is great - doubles the Quake and PCPlayer 640x480 performance! It gives some errors though so will need to experiment a bit. /auto only worked on a clean DOS mode, with sound drivers etc it crashes for me.
If this is of any interest, this is what I see when I run it...
Ah this is a very tricky case... It detects the voodoo card's BARs as VRAM that should be accelerated, and that in conjunction with the memory on your TNT1 makes for 3 potential MTRRs needed, so it doesn't know what to do and gives up.
I don't know how to handle this case better, because the tool can't know what you actually want to do. I could convert this error into a warning maybe, or stick to true VGA adapter LFBs only (i think it can be discerned via the PCI subclass code)...
Any input how the logic can be structured better is welcome.
EDIT: wait - you're running a voodoo 3 in parallel with it? Yeah, then that can't be done automatically, you need to set the MTRRs you want by hand, I don't see any way to handle that automatically 🤔
Chain-Q wrote on 2025-01-04, 12:38:
First of all thanks for doing this tool, I'm blown away by the performance increase I'm seeing, from most graphics stuff using […]
First of all thanks for doing this tool, I'm blown away by the performance increase I'm seeing, from most graphics stuff using the LFB. (Demos!)
However, I also have some problems. At least with version 1.1, on my system, I can't seem to be able to load it from CONFIG.SYS. I get a message: "Keep C fatal error: Unable to fixup segment references." (see the attachment; direct capture from the VGA out) and then the system is locked up. Same before/after HIMEM.SYS is loaded. Also when EMM386 is loaded, K6INIT dies immediately after pressing ENTER at the prompt. No messages. Even if I just do K6INIT /?, the executable just stops. Note that the two things are independent from each other. K6INIT dies from CONFIG.SYS, even if EMM386 is not loaded.
I'm using the 1.1 release binary from GitHub. I use PC-DOS 7.01 (a.k.a. PC-DOS 2000). But as far as I know, this should be just MS-DOS with some tweaking/tuning from IBM, so the compatibility should be very high. My system is a K6-III+/400@550, AGP Riva TNT 1, Acorp 5ALI61 mainboard, 512MB RAM.
Do anyone else see similar problems, or it's just my setup, as usual?
It is probably a bug within Geoff Chappell's KEEPC library, a implemention detail discrepancy in PC-DOS that trips it up. I can see if I can fix it manually but there is some wizardry in there that's way over my head....
Also since I rarely check this place for obvious reasons - please feel free to open bug reports on github (https://github.com/oerg866/k6init/issues), so I can respond and fix problems a bit faster, and it also helps me keep track of them 😀
Reply 67 of 92, by Chain-Q
Oerg866 wrote on 2025-01-17, 23:33:
As you wish. Opened two bugreports on GitHub for the EMM386 lockup issue (it should still exit gracefully, IMO) and for the CONFIG.SYS load issue have.
AMD K6-III+/400@550, 512MB, Diamond Stealth V550, Gravis Ultrasound MAX 1MB, Sound Blaster AWE64
C= Amiga 2000, Motorola 68060@50, 128MB, Cirrus Logic 5446A 4MB, ESS 1688 + TI 486sxlc2@50 8MB
Mastodon
Reply 68 of 92, by Oerg866
Thank you! I'll try and debug this when I get the time 🥳
Reply 69 of 92, by SteveC
Ah this is a very tricky case... It detects the voodoo card's BARs as VRAM that should be accelerated, and that in conjunction w […]
Yeah it's a Voodoo 3 card. It has onboard ATI AGP but I'm not using that, there's no TNT1 in there!
Reply 70 of 92, by tauro
I'm testing it with a K6-2 450@533 on a GA-5SMM (SiS 530 + SiS 630).
With /auto it doesn't improve performance, but /auto /vga does work.
Is this the best way to use the software?
Previously I used to run:
K6WCX E4000000 64 A0000 1
QUAKE 640x480 goes from 27.2 FPS (K6WCX) to 31.2 FPS (K6INIT /auto /vga).
Reply 71 of 92, by RoberMC
I tried this program and... I am experiencing a performance boost that exceeded my expectations by a lot, an abnormal performance boost, and my system was already optimized with write combining enabled and all the stuff, so I thought I would do some investigation...
My system:
AMD K6-III+ 575Mhz (115*5)
Asus P5A-B (Ali Aladdin V)
Voodoo 3 3000 AGP
256MB RAM
This motherboard has options in bios to enable write combining and frame buffer stuff, so i wasn't using any of the other WC enabler tools, like K6WCX, as they made no measurable difference when I tested them.
I was getting 29.4 fps in Quake 640x480 dosbench test, which is a bit more than what Philscomputerlab was getting in his review video of this tool, so I thought this tool would not do anything for me, another K6WCX tool but fancier... oh, I was so wrong...
With the exact same configuration I executed K6init /Auto and now I am getting 40.1 fps in Quake 640x480, that's a 37% increase, and this made Quake2 (Q2Dos port) playable over 30fps at 640x480!.
Here's some test results from dosbench with Bios tweaks and K6INIT:
Chris's 3D bench 640x480 (4) : 212.7 Score
PC Player 640x480 (6): 81.0 fps
Quake 640x480 (e): 40.1 fps
And here the same tests with K6INIT only:
Chris's 3D bench 640x480 (4) : 136.8 Score
PC Player 640x480 (6): 49.0 fps
Quake 640x480 (e): 28.6 fps
This lead me to think there's more room to improve what this tool is doing to squeeze even more the k6, at least on ALi chipset.
I remember years ago I managed to trace what the bios in this MB is doing with chipset registers and used pciset tool to replicate the behavior in order to transfer this tweaks to motherboards lacking this bios options, it is flipping some bits in 3 southbridge registers 84 85 and 86. South Bridge is Ali M1541, Vendor 10B9, Device 5243
Bios configuration by default (wc fb off in bios):
PCISET 5243 10B9 84 1111 0000
PCISET 5243 10B9 85 1111.1111 0000.0000
PCISET 5243 10B9 86 1111 000
Bios tweaked configuration (wc fb enabled):
PCISET 5243 10B9 84 1111 1111
PCISET 5243 10B9 85 1110.0000 1110.0000
PCISET 5243 10B9 85 0000.1111 110
PCISET 5243 10B9 86 1111 111
I tried this in other Aladdin V motherboards which do not have this options in bios, like the GA-5AX and Diamond Mironics C200, and got about the same performance as with the Asus and now with K6INIT the performance went over the roof. This bit masking and flipping thing makes my head hurt and probably the same results can be obtained with less commands, i'm not an expert. The bits to set can be deducted from the PCISET syntax.
The idea would be to integrate this chipset tweaks into the k6init tool if that's possible and... boom, more free performance for everybody!
Also, as a feature request, I would like the tool to have an option to output less text, a line or two would be great to know it's working as I like to have my boot screen less bloated, I use it in config.sys, so >NUL doesn't work.
I hope this post is helpful.
Reply 72 of 92, by 1541
tauro wrote on 2025-01-23, 11:52:
"/auto" sets
"- Finds linear frame buffer memory and sets up write combining for it\n"
"- Enables Write Allocate for the entire system memory range\n"
"- Enables Write Ordering except for uncacheable / write-combined regions\n"
but excludes unsafe features that might freeze the machine, so you need to set "/vga" explicitly.
"/vga" sets
"Enables Write Combine for the VGA memory region"
"(A0000-BFFFF). WARNING: Potentially unsafe."
"You MUST NOT use this memory region for UMBs."
"This parameter is equivalent to /wc:0xA0000,128,1,0"
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 73 of 92, by marxveix
Its not directly related to k6, but is it possible to enable similar boost with slot a k7 or socket a k7?
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
Reply 74 of 92, by BitWrangler
marxveix wrote on 2025-02-10, 19:39:
Along with being more or less a clean sheet design and getting a lot of DEC Alpha features, the Slot and Socket A CPUs were on motherboards specifically designed to use them, all the magic was implemented in chipset and BIOS. This is in contrast to the more "multipurpose" recycled socket 7 nature of the platforms for K6-x.
Reply 75 of 92, by Falcosoft
K7 uses the same memory type range registers as Intel P6+ so you can use the same tools to set write combining for linear and VGA frame buffer:
https://www.philscomputerlab.com/dos-graphics-boost.html
But in case of setting WC for the VGA frame buffer there is a quirk:
MTRRLFBE and AGP/PCIe cards in DOS
Website, Youtube
VST Midi Driver Midi Mapper
Reply 76 of 92, by nickles rust
Thanks for all your work on this! I have been using it on a PC Chips M530 with a K6-3+ CPU. The bios does not recognize the CPU, but it will still boot with the caches disabled. If I run "k6init /auto" after booting, it will hang the system. However, if I first enable the caches with "setmul l1e", then I can use k6init to enable the other features.
Also, I would suggest that the /? and /help options do the same thing.
Reply 77 of 92, by mockingbird
In config.sys, I have RLOEW's limitmem.sys as the first entry to limit my ram to 16mb. I also have memory hole enabled for 15m-16m in my BIOS (otherwise limitmem.sys doesn't do anything).
Then I have k6init loaded before HIMEM and EMM386 with "/auto" set, and then I have a second line separate from the first with "/vga" set.
With the first entry, everything succeeds except "write allocation" which fails. The second k6init initialization with "/vga" also succeeds.
If I load "/auto" and "/vga" together, I get multiple failures and it doesn't work (in other words, I have to call "/auto" and "/vga" with two separate consecutive entries in config.sys).
With only "/auto" loaded, I get little or no performance increase (maybe because write allocation is failing)?
But with "/auto" and "/vga", I get a massive performance increase in DOSBENCH's "3DBench 1.0c (Faster PCs)" which jumps from around 200 to over 500.
System is a K6-3+ running at 83Mhz x 6 (500Mhz) on an Asus SPAX cross-flashed to an SP97-XV (read: SiS 5598 chipset).
To compare, on my Pentium 4 Northwood at 1.6Ghz with only MTRRLFBE enabled, I get a score of 700.
Still, I would like the "/auto" to work properly with my setup - perhaps the author has some suggestions?
Also, perhaps it would be prudent to add a switch to the program to silence the output? ">nul" won't work because it's not being called as an entry from a batch file.
Thanks.
(Decommissioned:)
Reply 78 of 92, by Oerg866
Hello,
I've just released v1.2 of K6INIT.
Some of the points raised earlier in this thread and also your issue @mockingbird should be addressed now.
https://github.com/oerg866/k6init/releases/tag/v1.2
- Write Allocate no longer fails when the 15MB hole is specified
- Reworked behavior of /auto with other parameters, it is now seamless
- Introduced new skip parameters that help change /auto's behaviors
- Running in V86 mode no longer crashes (fixes #2) but gives a helpful message
- added /quiet parameter for reduced print output
- PCI / LFB scan warns instead of errors when the MTRR list is full (i.e. too many locations found)
Reply 79 of 92, by mockingbird
Oerg866 wrote on 2025-07-09, 04:23:
<snip>
Thanks, I will test and report back. My modded K6-2+ is currently sitting in a c-clamp while the glue dries.
(Decommissioned:)
