Reply 80 of 139, by igna78
Oerg866 wrote on 2025-07-09, 04:23:Hello, […]
Hello,
I've just released v1.2 of K6INIT.
Some of the points raised earlier in this thread and also your issue @mockingbird should be addressed now.
https://github.com/oerg866/k6init/releases/tag/v1.2
- Write Allocate no longer fails when the 15MB hole is specified
- Reworked behavior of /auto with other parameters, it is now seamless
- Introduced new skip parameters that help change /auto's behaviors
- Running in V86 mode no longer crashes (fixes #2) but gives a helpful message
- added /quiet parameter for reduced print output
- PCI / LFB scan warns instead of errors when the MTRR list is full (i.e. too many locations found)
Absoluty fantastic new!
Thank you very much for your job!
