First post, by Chmosia
Hi, new here 😉
I have old sony 2 gb ram netbook with win 7 on board.Unable to watch HD videos,they are freezing and CPU goes to 100%.
If i flash Linux as second OS,will i be able to watch H256 videos smoothly?
asas
Reply 1 of 4, by Archer57
Chmosia wrote on 2025-07-11, 06:54:
Unsurprising. That's normal.
No.
Though when asking a question like this you really should provide more information like specific hardware specs, specific video format/resolution/bitrate ("H256" does not exist, is it 265?), etc.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 2 of 4, by ntalaec
If the computer has Windows 7 the CPU could be an Intel Atom N280, which can't handle 1080 H.264 or even 720p H.264 with high bitrate. An Intel Atom Z3735F could play H.264 but not H.265.
Reply 3 of 4, by ott
Hi, new here 😉
I guess the Broadcom Crystal HD (BCM970015, mini PCIe card) can help for decoding h.264/AVC videos, but not sure about the software support/compatibility in nowadays.
Reply 4 of 4, by DudeFace
Hi, new here 😉
probably not if your cpu is at 100% your out of luck, you may have to stick with H264, i use an old core2 duo e5400 at 2.7ghz and H265 is jumpy as shit and cpu is at 100%, i overclocked to 3.25ghz and videos were smooth and cpu usage dropped to about 30%, if you can overclock its probably still more than an x86 single core atom can handle
ive got a single core 1.6ghz atom that used to run win7 and it was slow as shit just browsing the internets. would make a good low end xp gaming system tho.
