Wish me luck
First post, by Matth79
Bought an Asrock 775dual-VSTA "untested", boxed, clean, all accessories.
Maybe a great board, but possibly a retro wall hanger
Reply 1 of 12, by AlexZ
How much did you pay for it?
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 2 of 12, by Matth79
AlexZ wrote on 2025-07-09, 12:46:
£59.50 including international post... I have to bring it to the front of my testing queue, except that feels like rubbing off a scratch card or checking lottery numbers... win or lose time
Reply 3 of 12, by paradigital
Hopefully you’ll get lucky. My £50 boxed “untested” 4CoreDual-SATA2 was fortunately a working board.
It’s been a great testbed.
Reply 4 of 12, by RetroPCCupboard
Nice. It is unusual to have both AGP and PCIe. Are you planning to use it for a test bench?
I got a ASUS P5VD1-X for test bench use. Though, not ideal as the PCIe slot is only 4x, and the AGP doesn't support 3.3v cards
Reply 5 of 12, by AlexZ
Asrock 775dual-VSTA has pcie x4 only as well. Max memory capacity 2GB puts it into Windows XP territory.
Reply 6 of 12, by RetroPCCupboard
AlexZ wrote on 2025-07-09, 20:00:
The retro Web says it supports 4gb if you use DDR2? Unless I am reading it wrong. Mine supports 4Gb DDR1.
Reply 7 of 12, by RetroPCCupboard
I think I read somewhere that this chipset doesn't like dual GPU cards. Like the GTX 295. But I don't have such a GPU to test
Reply 8 of 12, by Matth79
4GB with the beta BIOS, as well as 45nm support, need to clear a test bench spot, find a suitable test victim GPU - no onboard
Final target, XP AGP, with a HD3650 AGP, I'll go 2x 2GB 667 (correction, dual 533 to sync up to the 1066 FSB) if the beta BIOS does open >2GB, I did have another AGP platform, P4M800PRO-M, but it was limited to P4/Pentium D and only single channel 667, I just didn't like it for the 3650 - oh and it is apparently very fussy on PCIE, being 1.0a (which is SUPPOSED to be compatible with 2.0 card auto negotiation), and only x4.
This is not a platform you would choose for PCIE as there are far superior LGA775 PCIE platforms that are also way cheaper
Reply 9 of 12, by RetroPCCupboard
Matth79 wrote on 2025-07-09, 21:00:
That's true. I wouldn't want to build a PCIe system around it. But, for me, these AGP/PCIe boards seem a great idea for a test bench to quickly stick newly acquired GPUs in to check that they show a signal and have no memory artifacts when benchmarking. One its passed that test, you can either store away away the GPU or decide if you are going to build a system around it
Reply 10 of 12, by H3nrik V!
RetroPCCupboard wrote on 2025-07-09, 21:28:
Exactly what I was thinking 😀
Reply 11 of 12, by Jasin Natael
I used to have one of these boards. It's on the "why did I ever get rid of that!?" list.
Reply 12 of 12, by [FMC]Ravage
That's a steal honestly. Most are going for at least double that on ebay. Asrock made some interesting frankenstein boards at the beginning. They were meant to be cost effective alternatives to Asus boards but ended up having the positive side effect of bringing newer tech to Win9x.
