First post, by junak
Hi, I can't get the sound card to work on this motherboard. It works fine on a socket 7 motherboard. It's not detected here. Does anyone have any ideas?
RETRO Soyo SY-5XA + Pentium 166MMX + 32 MB RAM + S3 Trio 3D 4 MB VRAM + ESS AudioDrive ES 1869F
MODERN MSI MPG Z690 EDGE WIFI DDR4 + I7 12700K (stock UV) + 48 GB RAM 3600 MHz DDR4 + RTX 4070 Ti 12 GB VRAM
Reply 1 of 5, by Grzyb
There are two replacements for ESSCFG:
1. another version of ESSCFG, you can try these:
Re: Can't use IDE port on BTC 1857i card (version 5.1)
https://web.archive.org/web/20000229161511/ht … vers/driver.htm (version 5.2)
2. UNISOUND
Reply 2 of 5, by Horun
Did you disable the "Onchip sound" in the Advanced setting in BIOS ? just curious....
Reply 3 of 5, by junak
Yes Onchip is off but still dosent work, esscfg 5.1 and 5.2.
Reply 4 of 5, by Grzyb
What about UNISOUND ?
And what about any software that lists ISA PNP devices? BIOS, HWINFO, Windows 9x ?
Are you sure the ISA slot is OK?
Reply 5 of 5, by junak
OK, it works. I cleaned the card's contacts with a cloth and it started working. I also cleaned the ISA port with isopropyl alcohol.
Thank you very much.
