Reply 20 of 24, by snufkin
ksiumaxx wrote on 2025-06-18, 12:57:Sorry for not responding, somehow I missed your message.
Nope, pin 2 is not connected to anything. Should it be for the trackball to work as a serial mouse? When I looked up the model on the internet I also only saw pictures of one with the 25 pin serial connector; none with the 9 pin. I assumed it was a PC mouse because I knew that Highscreen made IBM compatible PCs. Could it be that the trackball I own is an Amiga/C64 type mouse?
Sorry, I also missed your reply. It's odd, I think it probably is a serial mouse, with all those transistors for doing level shifting and weird split power supplies for the chip and LEDs. Are there any labels on the bottom of the case, if so, could you post a picture? But I'm fairly sure that a serial mouse would have to have something connect to pin 2 on the computer's serial port as that's the receive data pin. I'm sure someone can correct me if I've got that wrong.
Maybe someone tried swapping the connector or cable in the past so they could plug it in to a 9 pin port, but got it wrong? I'm slightly worried about the burnt resistor, I didn't think a serial port could supply enough power to do that, so maybe the chip or LEDs have also been damaged.
I hope you don't mind, but can we just double check which pin you're measuring as pin 2? If there's a label that suggests it is a serial device then we could have a go at guessing or working out what the pinout should be and rewiring it. I've managed that once before when working out an adapter for a dual serial / ps/2 mouse.
