First post, by AndreaColombo86
Hello, everyone!
This is my first post on VOGONS.
I’ve been toying with the idea of getting a PC for retro gaming for a few years now and it looks like I might finally be getting somewhere with this.
I have my eyes on a retro PC that comes with Windows XP SP3 installed and activated. That’s fine and I don’t want to lose it, but I really need Windows 98 SE for those sweet EAX occlusion effects in Baldur’s Gate—so I thought, perhaps I could dual-boot both OSs.
Problem is, I have no idea how it’s done. Any help would be appreciated 😀
Reply 1 of 9, by GemCookie
Install Windows 98 first. Upon installation, Windows XP will prepare a boot menu with two entries: one for 98 and one for itself.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Ubuntu
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Arch/OBSD
Reply 3 of 9, by dr_st
Indeed it's easier to first install Win9x, then XP. Because XP recognizes Win9x automatically, but not the other way around. Win98 will probably trash the XP boot sector.
If you don't want to wipe the existing install, there are ways to fix / work around it. I've documented some of them here.
ott's suggestion has its own advantages, I would try that first, if you already have WinXP installed.
Reply 4 of 9, by lolo799
I did just that not long ago on a laptop.
I used this tool to reduce the size of the XP partition after defragmenting it. It was freely downloadable from https://web.archive.org/web/20160310034551/ht … m/download.html
And it's mirrored at https://archive.org/details/minitool_partitio … ee_edition_v9.1
Installed Win98se, then you have the choice of installing BeOS Personal Edition under Win98 (if your hardware is supported) and install bootman (the BeOS bootmenu) from the Terminal.
Or boot from a Haiku livecd and install its bootmenu.
It will show one entry per partition and will works flawlessly.
Reply 5 of 9, by AndreaColombo86
If I wanted to install Win98SE first, how would I format the existing WinXP installation?
I used to be able to do this stuff but it’s been so many years…
Reply 6 of 9, by GemCookie
The Windows XP partition can be formatted from a Windows 98 boot disk. Navigate to the installation medium and run "extract ebd.cab format.com"; this will make the format command accessible. Formatting the partition from a later Windows installation medium is also an option.
Reply 7 of 9, by AndreaColombo86
GemCookie wrote on Yesterday, 15:13:
Would you say it’s easier from WinXP’s disk?
Reply 8 of 9, by GemCookie
AndreaColombo86 wrote on Yesterday, 17:54:
The Windows XP installer is more likely to allow a quick format.
Reply 9 of 9, by chinny22
First things first what are the system specs? Are you sure the hardware supports Win98?
Second WinXP still has EAX support (It's the last OS that does) so if thats your main reason for the downgrade then no need!
If you want to install both just for nostalgia then that's perfectly valid reason.
Personally I work on the theory prepare the system with the earliest OS and your guaranteed full compatibility.
So in this case, I'd use Fdisk to partition the drive. Typically I go with
4GB Fat32 Primary partition for Win98 (C:\)
Extended Partition
Large Fat32 Logical partition for games and data (D:\)
10GB NTFS Logical partition for WinXP (E:\)
This will mean your drive letters remain the same no matter which OS you boot into (E: will just disappear when in Win98)
It also means if you need to reinstall all your data is safe in its own drive.
I would finally say it may be worth getting a second hard drive to test with. leaving your currant hard drive safe in case everything screws up
