Reply 3000 of 3589, by robertmo3
vs and msys2 are two different compiling applications.
you use either one or the other not both.
Reply 3001 of 3589, by robertmo3
i was thinking if it doesn't work in vs2022 then try vs2019 next 17, etc.
2005 is probably too old
Reply 3002 of 3589, by sharangad
robertmo3 wrote on 2025-07-16, 10:56:
When you try to build seabios it actually says some feature is deprecated after VS2005. I'll give that a shot later.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3004 of 3589, by sharangad
RaVeN-05 wrote on 2025-07-16, 18:25:
tested today Rebel Moon works perfectly. […]
tested today
Rebel Moon
works perfectly.
probably dosbox usiues
game crashed once
music in game often turnoffs by itself , never happened on my retro pc.
Thanks Raven-05!
I've never tested the game beyond the first two levels. Once we get CGL going it'll be interesting to see if that still happens. I did once get a "division by zero" crash.
Reply 3005 of 3589, by sharangad
tested today
Rebel Moon
works perfectly.
game crashed once
Does it use CD-Audio?
Reply 3006 of 3589, by RaVeN-05
not audio cd, audio tracks stored at cd drive in music folder as wav files.
Edit
P.S. Best way to play rebel moon in wasd+mouse is to use novert
https://www.doomworld.com/idgames/utils/misc/novert
which will disable walking forward / backward by mouse movement up/down.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3008 of 3589, by sharangad
RaVeN-05 wrote on 2025-07-17, 19:55:
also reshade not compatible to dosclient.exe it crashes it , letting know , the lowest possible priority
I think you mentioned this before, about reshade not working. Vertex data is mostly passed on to the shaders in rendition internal formats, the way it's passed to the wrapper, for two reasons :
1) converting each vertex to floar manually one vertex at a time is slow and is best done in parallel on the gpu,
2) for performance, the vertex data is passed as a massive blob to opengl/gpu. The floating point conversion would need a duplicate blob involving slow dynamic memory allocation.
So passing native data saves memory and improves performance.
The quake span shader (qspan) uses acompletely different format. Some shaders have a geometry shader stage and others do not. I could fork reshade to support all this or migrate some reshade functionality directly into rready.
Reply 3009 of 3589, by sharangad
One more Rendition Ready track: Toronto 2003 (not sure how I missed this in my earlier Toronto '95/'96  video):
https://youtu.be/fKmSAHWaVM0
and a few F1'96 (RRedline) demos:
https://youtu.be/89_0JEYV2lU
Reply 3010 of 3589, by sharangad
There's a strange bug here. A user over at icr2.net says [ALT+B] isn't toggling auto-brake. I tested this on real hardware and it works perfectly everytime.
I debugged this and Dosbox-Rendition seems to be getting the command but the game seems to be ignoring it OR Dosbox is swallowing it up.
Is [ALT+B] a super duper Dosbox 'do-nothing' keystroke? It doesn't look like it is.
Reply 3011 of 3589, by robertmo3
left alt is certainly not working correctly in rready, in tomb raider if you hit left alt while running lara stops running.
Reply 3012 of 3589, by sharangad
robertmo3 wrote on 2025-07-18, 05:06:
OK. So there's definitely something wrong with Dosbox-Rendition with left alt.
Reply 3013 of 3589, by sharangad
RobertMo3, can see if Tomb Raider works with this? It appears to work for me.
I think I've fixed all the ALT issues, but [ALT+B] still doesn't work in ICR2. ALTW, ALTM, ALTX and ALTR work perfectly. ALT B is missing in action.
https://nirvtek.com/downloads/RReady.Alpha.20 … 0718.001.Alt.7z
MD5: 49198698be674f03cf4aac097218ba86
The previous build had unnecessary logging.
https://nirvtek.com/downloads/RReady.Alpha.20 … 0718.002.Alt.7z
MD5: 75e00f459fa53022de52362aff6e38db
This build also fixes a bug in ICR2 for slower dual core systems when using:
threadsafe=true
highperformance=false
picdma=false
Unfortunately for me my dual core laptop died a few weeks ago and my i7 2600 with HD2000 graphics also joined it in the microchip park in the sky. So my testing options at the moment are limited.
@Raven-05, if you've still got your core2 laptop it would be useful if you could give it a whirl.
Reply 3014 of 3589, by sharangad
Ok, [ALT+B] does work in ICR2, holding it down toggle it. I think on physical hardware even a slight keypress registers for a bit longer than on modern Windows. The evidence for that is that holding [ALT+B] down for a long while cycles auto-brake very quickly, whereas on physical hardware there's a delay. It doesn't switch 5-10 times a second.
Does dosbox have a key duration/repeat setting?
Reply 3015 of 3589, by robertmo3
dosbox-x has:
MODE CON RATE=1 DELAY=4
RATE: Sets the repeat rate (characters per second). Valid values are 1-32, with higher numbers being faster.
DELAY: Sets the delay before repeating (in fractions of a second). Valid values are 1-4, representing 0.25, 0.50, 0.75, and 1 second respectively
Reply 3017 of 3589, by sharangad
robertmo3 wrote on 2025-07-18, 19:19:
dosbox-x has: MODE CON RATE=1 DELAY=4 RATE: Sets the repeat rate (characters per second). Valid values are 1-32, with higher num […]
dosbox-x has:
Thanks!
It looks like [ALT+B] gets passed to every single running process before Dosbox-Rendition gets it including background processes. One of them seems to be taking a while to deal with it.
Reply 3018 of 3589, by sharangad
https://nirvtek.com/downloads/RReady.Alpha.20 … 0719.001.Alt.7z
MD5: b39c3f8fd904e9707534a478ef2f21c2
- Autobrake can be toggled by an immediate tap of [ALT]+. This fix involves adding an 0.066 second delay to the key sequence release. For some reason on Windows 10/11 This shortcut runs much faster (under 1 ms) whereas all the other [ALT] shortcuts take more than a millisecond. The sequence is so fast that ICR2 didn't detect the keystroke unless they keys were held down.
Reply 3019 of 3589, by sharangad
*** This is not a production build ***
This is a real Alpha (not fully tested) build:
https://nirvtek.com/downloads/RReady.Alpha.20 … ICR2.Cockpit.7z
MD5: 07ce1a33180c12d543667edc7edf213e
- ICR2 cockpit toggle should work without stuttering. There may be input lag. Needs one more CPU thread.
This should fix the F10 cockpit view toggle, but the keyboard input might lag horribly. I would be very interested in feedback.
