Saving defective chips with improvised cooling?
Reply 20 of 26, by myne
The playstation guy specifically states in one of his videos that the penny trick is stupid.
Extra pressure doesn't help and most likely hurts.
I built:
Reply 21 of 26, by Vany
myne wrote on 2025-07-15, 05:37:
The heatsink was not making full contact with the chip itself, Only 3/4 of the chip was covered, in this case, it helped. I haven't used a penny but an aluminum washer since it was glued to an aluminum part anyway.
Trident Cyber 9525DVD Test, Review and supported games list
Reply 22 of 26, by Vany
Archer57 wrote on 2025-07-15, 05:32:
Did you use glue which can handle up to 100C? It may fall off otherwise... Also should be really careful with this - pretty easy […]
Vany wrote on 2025-07-15, 05:17:
I went with "Solution C" and modified the heatsink by gluing a single 1mm washer on top of it so that the keyboard keeps it squeezed down.
Also should be really careful with this - pretty easy to break the die if you apply uneven pressure. I'd be pretty hesitant to keep it "squeezed" by keyboard just in case i type on it with a bit too much force...
Now that I've confirmed though that the Radeon chip in the T500 is good, I'll do some stress testing.
Be careful with this. I am not sure it is a good idea to torture old chip with stress tests. If it's working i'd just use it normally and hope it lasts, no reason to basically do accelerated aging/wear on purpose...
I don't believe the Mobile 3650 can reach such temperatures, it is a mid range chip, but if the glue fails, the keyboard will hold it down. Initially I tried with two washers but there was an obvious bump when I started tightening the screws, so I removed one and just kept the one. There is no curve on the keyboard now, don't worry the chip still works 😀
Regarding the stress testing, there won't be any overclock, I plan to only use the laptop as it normally would be used so I'll test video encoding, 3dmark, some actual era-specific games for that chip and such and that is it really. Either way it is a mid-range chip from 2008... if it can at least show me how it behaves after I've done the bare minimum to ensure that it has factory-cooling, stock airflow and clean heatsinks. Goal is to have it under 70C when it plays a heavy game like Crysis. If it doesn't, I'll see what I can do to modify the cooling further.
TLDR: I want to give it the best possible chance at surviving normal workload under "normal" conditions.
Reply 23 of 26, by Archer57
Vany wrote on 2025-07-15, 05:51:
It can, and probably does, most laptops i've seen bump against 100C or so limit...
Just be careful - it may fall off over time and short something... may be worth getting something automotive just to be safe. I've used gasket sealant for stuff like this before 😀
Yeah, that's fine. Some people like to run 3dmark on a loop overnight, or worse - furmark. I personally consider that... questionable idea. Especially furmark - it creates much more load than any real task would and can outright kill chips which do not have power limit yet.
Reply 24 of 26, by Vany
Archer57 wrote on 2025-07-15, 06:12:
It can, and probably does, most laptops i've seen bump against 100C or so limit... […]
The moment the temps become unsatisfactory I'll stop the testing - in this case, gpu above 70C. After that I'll go and mess with the heatsink again, see if I can Frankenstein something to keep the temps low. Sadly the CPU is also one of the hot ones and isn't helping the situation. Original goal was Max 60C but I don't think that is possible without an additional fan... I'll post my results here when I'm done though!
Reply 25 of 26, by Vany
If someone knows what the deal with this laptop is, when I install latest official HD 3650 drivers, laptop restarts, install fails. When I Install latest windows 7 drivers, the laptop bluescreens. When I install random non-latest drivers, it works fine, but those drivers lack the switchable mode. I don't know where to get older switchable drivers 😒 At this point I am not sure if the 3650 is "done" or if the drivers are really that awful.
The T500 is an awful machine, I have to say. It is the hottest laptop that I own, hot to the touch from the bottom so much that I can't even hold it. How did it get so hot? Just the browser was running...
Reply 26 of 26, by Archer57
So does the card work with some drivers in some configuration? Because if it does you can probably consider hardware functional. If it does not it may very well be dead.
But yeah, "frustrating experience" is how i'd describe my own interactions with AMD graphics from that time period. AMD drivers are really that awful, especially when switchable graphics are involved. It is frustrating and so bad it is hard to figure out is it still drivers, or if hardware is faulty. That said - do not get stuck on it too much - if nothing works at all it is probably hardware.
