I was in the process of testing the thing after finally finding all the good drivers that play nice. Everything was set to performance but framecapped at 60 fps. The laptop managed to play ziggurat and flatout 2 without any issues at max resolution, then I tried Crysis. Autodetected medium settings, so went with it. GPU temp reached 120C!!! Then the laptop shut itself down... The images show that the fan is at 30% but that is incorrect, I used ThinkPad Fan Control and set the fan to max.
120 degrees celsius... with Arctic MX4 freshly applied days before, with heatsink tightly pressed against the chip. Sadly I haven't managed to take a picture of this before it shut itself down, but I did manage to take two, one at 108C and another at 112C when I set the game to all low settings.
I mean... who would have even thought that ONE THIN COPPER PIPE would not be enough for a 35W CPU, a Mid-range GPU that uses 35W and an intel integrated gpu that draws 13W...
Well, I have nothing to test with this machine anymore. The 3650 still works after it cooled down and I don't want to cook it, there is barely enough room inside to place another fan but it will still all be cooled by that single copper pipe. I don't know what to do with this laptop now, I wanted to preserve it but it's kinda pointless since it was quite obviously designed to fail. The only reason I think it didn't was because it was used by some seniors before I bought it (Wipe your HDDs before you sell your laptops peeps!) and it was set only to use Intel's GMA 4500. Kudos to Lenovo, but hiring oven/barbecue engineers to do cooling for a laptop isn't the way.
Pics are here https://imgur.com/a/LmcijAk
I recorded 10-15 minutes of the machine in action, might do a yt video later.
