EAX appreciation thread
Reply 580 of 1157, by Joseph_Joestar
Barley wrote on 2025-07-12, 14:24:
Right. According to https://www.vogonswiki.com/index.php/List_of_ … ith_EAX_support Colin McRae: Dirt only has an X in the EAX 5.0 column, while Quake 4 has an X in the 4.0 and 5.0 columns. So what happens if I use an Audigy RX card with Colin McRae: Dirt? Do I get no EAX effects at all?
Doesn't look like anyone here has tested that yet. Try it, and let us know if it works. I can amend the wiki page if it does. For reference, with EAX 5.0 enabled on an X-Fi card, it shows up in the options menu like so:
file.php?id=217948&mode=view
If EAX 4.0 is supported, I imagine it should appear there too.
My retro builds
Reply 581 of 1157, by Barley
Thanks. F1 2010 and Race Driver: Grid are two other titles that only have an X under EAX 5.0 that I am curious about. I would test it myself but don't have the games (yet) 😀.
Reply 582 of 1157, by sharangad
Barley wrote on 2025-07-12, 14:55:
Colin McRae Dirt Demo runs and shows EAX 5.0 in OpenAL 3D High mode. I don't know whether EAX is working though. Surround appears to be.
https://youtu.be/hKu00OkDzqw
The other two games I'll check out later.
Generally, if the game uses the EAGL library there's some sort of fallback to an earlier version.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 583 of 1157, by sharangad
F1 2010 doesn't have a demo and the GRID demo doesn't seem to support hardware accelerated audio. That might just be the demo. There's no OpenAL file or anything in there.
I don't own these three games and I tried just the demos.
Reply 584 of 1157, by UCyborg
sharangad wrote on 2025-07-12, 10:20:
NFS High Stakes: CMSS On and Off https://youtu.be/pabOQ_4ZH2w
Unfortunately I didn't try selecting the same track for each go, but the difference is audible. There're quick jump chapters in the video details.
I think it's safe to say stereo music loses something with CMSS turned on.
You're right, it's a shame, music can be big part of the atmosphere. Creative surely won't lift a finger to improve any of this tech, so things may just stay as they are unless someone improves OpenAL Soft + DSOAL. I have a hunch it's more on OpenAL Soft then DSOAL.
I once made Creative ALchemy's dsound.dll wrap to soft_oal.dll, Mafia had the same glitches as if DSOAL's dsound.dll was wrapping.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 585 of 1157, by willow
a driver fix for openal bug with xfi titanium pcie-express card introduced in 2.4x drivers ? Thanks
Reply 586 of 1157, by Joseph_Joestar
willow wrote on 2025-07-18, 20:28:
If you're using WinXP or Win7, you can follow my guide. It uses the older 2.17.0008 driver which doesn't have the OpenAL bug.
But if you're on Win10 or Win11, you may instead want to try DanielK's X-Fi pack, or alternatively Antes533's modified drivers. Both of them fix the OpenAL bug, but do so in different ways.
My retro builds
Reply 587 of 1157, by sharangad
Bioshock original with working EAX
EAX wasn't working in the earlier video. It is in this:
https://youtu.be/K-cZkhtvpnM?si=KmgVxTasH2KTwVQ4
The song at the beginning had been stripped out by YouTube because of copyright issues.
Reply 588 of 1157, by Joseph_Joestar
sharangad wrote on 2025-07-19, 01:57:
I played through it a few years back on my X-Fi Titanium, and I really liked the EAX implementation.
Sound propagation through the environment was very realistic, and positional audio was superb on my 5.1 setup. Due to the nature of BioShock's setting, there are a lot of places where occlusion and reverb are used really well.
My retro builds
Reply 589 of 1157, by sharangad
Joseph_Joestar wrote on 2025-07-19, 03:15:
Yeah the sound is messed up on the Audigy.
Reply 591 of 1157, by willow
Joseph_Joestar wrote on 2025-07-18, 20:47:
Daniel pack don't fix openal bug.
Reply 592 of 1157, by Joseph_Joestar
willow wrote on 2025-07-20, 19:01:
While I haven't tested this myself, the changelog for the latest X-Fi pack on DanielK's website claims that OpenAL works fine in games which use it.
But as mentioned before, there are also other options, depending on which version of Windows is used.
My retro builds
Reply 594 of 1157, by Joseph_Joestar
sharangad wrote on 2025-07-20, 21:02:
Star Wars KOTOR: EAX 3 on Audigy RX:
https://youtu.be/B7siBa3BzEU
I don't think EAX is used much during the early levels in KOTOR.
A bit later, you can hear it in some of the underground areas on Tarsis, and it's especially noticeable in the crystal caves on Dantooine. This game uses it sparingly, which is fine for an RPG.
My retro builds
Reply 595 of 1157, by sharangad
Joseph_Joestar wrote on 2025-07-21, 07:08:
You can hear it in some of the underground areas on Tarsis, and it's especially noticeable in the crystal caves on Dantooine. This game uses it sparingly, which is fine for an RPG.
I'll try Tarsis's cavern. Isn't that the bit with the prophesy? Or is that another planet?
Reply 596 of 1157, by Joseph_Joestar
sharangad wrote on 2025-07-21, 07:27:
Taris is the first planet, where you crash land initially. There, I mostly noticed EAX usage in the sewers and some other underground areas.
Dantooine is the second planet that you visit, the one where the Jedi Council resides. The crystal caves are there.
My retro builds
Reply 597 of 1157, by sharangad
Joseph_Joestar wrote on 2025-07-21, 07:34:
I'll do another video in a cave for KOTOR.
Meanwhile here's Drakan:
https://youtu.be/K0eKUydsugw
Reply 599 of 1157, by UCyborg
sharangad wrote on 2025-07-23, 11:54:
Inside the church uses auditorium preset, the entry part uses cave preset. Level Editor says EAX volumes are set to low levels, so I guess it's correct that they sound subtle / quiet, which was my initial observation in other areas of first level.
