The Need for Speed Special Edition for Windows "DOES WORK"
Reply 80 of 90, by BEEN_Nath_58
myne wrote on 2024-05-17, 07:24:
I realise I'm late and haven't read the whole thread, but I got nfs porsche 2000 running on w10 via the nvidia voodoo wrapper whose name I forget right now.
Nvidia Voodoo wrapper? I guess you mean 3Dfx Voodoo wrapper
Reply 81 of 90, by myne
Nglide.
I built:
Reply 82 of 90, by Nicknine
This is NFS 1 thread.
Reply 83 of 90, by presidente001
Hi friends! Work for me with configs below. My systen is Ryzen 7 5700x, 16gb ram, RX6700XT and Windows 11. Thanks a lot!!
BEEN_Nath_58 wrote on 2020-05-14, 06:06:
Well it worked for me on Win 10. How I achieved it: […]
Install NFSSE in C: directory of your main PC through DOSBox, that is files are located in C:\NFSSE
The dosbox code will be
mount c c:\
CD is mounted in the same drive as DOSBox.
My code was
mount L L:\-t cdrom(Substite L with the drive later where your cd is inserted in both mount and partition letter)
Use the same drive letter as in your PC to mount it in DOSBox(THIS WAS MY MISTAKE, I WENT TO EDIT PATHS.CFG)
Copy NFS WIN exe and Iforce dll and paste in nfsse directory. Rename NFS Win to nfs. Exe
Edit nfs.cfg and change the file starting which is usuallg SB16 in dosbox and change it to YESSOUND.
Use these compatibility fixes
EmulateCDFS
EmulateJoystick
IgnoreException
IgnoreScheduler
RemoveReadOnlyAttribute
copy dplay.dll from redist folder of game cd in case the dplay.dll from syswow64 gives ordinal error.
Run dxwnd and import the settings
https://sourceforge.net/p/dxwnd/discussion/ge … 0Speed%20SE.dxw
Change your game exe location dxwnd.
After you open the game, you may get some error relating to dserial like dpwsock and dpserial cant be loaded. Click ok on both cases. Your game will work
If you are in full screen mode and gane freezes on black screen, click windoes button and click ok on both msgs and get in the game from taskbar.
I hope this works for you. After 5 years I finally did this
You might also get errors relating to RGB. If that happens, click ok and retry to start the game until it doesn't shoe this msg and you get the. Dpwsock or dpserial msg.
This should work on all other OS
Reply 84 of 90, by neis
I came here to say that I cannot get the windows version to work without emulating a full windows (performance is pretty bad though).
However the DOS version I got it working (with some hitches and the occasional audio crackling)
Anyway, I used dosbox-x, because this is the one where I could keep the original aspect ratio without stretching.
And best of all, I can just launch it with a simple double click and it works!
I created a batch file to call dosbox-x with the custom config file which contains the necessary autoexec actions to start the game instantly.
As for the windows version, I've tried everything, and I cannot get the windows version to work unless I emulate a full windows environment. And no dxwnd didn't work for me, the game doesn't start and there are no errors...
So if someone has it working simply, and I mean with a double click and it launches (no further clicks needed), i'd like to know exactly what to do to make it happen.
Reply 85 of 90, by God Of Gaming
Dosbox is fine if you dont want to play with a force feedback wheel. I wish someone would make some sort of modern patch for the game, to run at high res and widescreen aspect, as its the only game in the series stuck at 640x480, even nfs 2 has a modern patch and can run in 4K
Reply 86 of 90, by BEEN_Nath_58
neis wrote on 2025-07-10, 18:53:
I came here to say that I cannot get the windows version to work without emulating a full windows (performance is pretty bad tho […]
Did you try this EXE
https://sourceforge.net/p/dxwnd/discussion/ge … A_access.fix.7z
Reply 87 of 90, by willow
God Of Gaming wrote on 2025-07-14, 05:01:
I don't think it's possible because it's not 3d engine used in nfs 1 and only software 2d engine and doesn't use direct3d. Windows version use directdraw.
NFS 2 is th first NFS that use 3d engine in software and glide.
It's the problem with all 2d engine and software engine even for 3d engine, modify resolution is difficult. A wrapper can't make it.
Reply 88 of 90, by Deffnator
I wouldn't mind a updated guide for this game and NFS2SE to run on modern windows, Hot Pursuit 1 is its own can of worms
Reply 89 of 90, by revolstar
If you guys want to play the original NFS on modern Windows in high resolution, why not try the PSX version through something like Duckstation? You can basically set any render resolution you like and play with a USB steering wheel.
Win98 rig: Athlon XP 2500+/512MB RAM/Gigabyte GA-7VT600/SB Audigy/GF FX5700/Voodoo2 12MB
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS3: Slim, CFW
PS2: Fat, FMCB
Dreamcast, GDEMU
Reply 90 of 90, by tgomola
Because there are version differences between PC and PSX. Not to mention, only PC got the Special Edition of the game with extra tracks.
