Socketing a soldered DS12887A chip
Reply 20 of 64, by multiplebaboons
shevalier wrote on 2025-07-30, 09:08:
Sorry for butting in. WHY don't you just break the chip with nippers/pliers and then desolder the pins one by one?
Because look at the first photo i posted in this thread. There is no access to the pins and this chip is insanely hard to break without messing up everything around it. I feel like i had no choice.
Reply 21 of 64, by shevalier
multiplebaboons wrote on 2025-07-30, 09:33:
Because look at the first photo i posted in this thread. There is no access to the pins.
Break the chip package.
Just bite off the corners with pliers, then the edges.
You rip off the cover with a screwdriver and take out the battery.
Then you gnaw out the remains of the IC.
It looks creepy in the process, yes.
But if the priority is to preserve the printed circuit board rather than the chip, then mechanical removal is always a priority.
PS
If only a few contacts are not desolder, insert a flat-head screwdriver under the chip.
Heat them one by one with a soldering iron, gently turning the screwdriver.
This will deform the printed circuit board a little, but it will not affect anything.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 22 of 64, by myne
Better than that.
Low melt solder.
It's magic for removals.
It doesn't just melt at a low temp, it stays in the malleable plastic state much longer allowing an easy removal.
It is also much easier to wick out once you've got the chip out.
No need to destroy anything with the right tools.
Additionally, it wouldn't hurt to bend a piece of solid wire into a deep u-shape that can touch all the pins on both sides.
Then you only have to heat that wire in a couple of points, and both rows melt as one.
I built:
Reply 23 of 64, by shevalier
myne wrote on 2025-07-30, 11:28:
yep, It would be best to use an infrared rework station or a vacuum station for desoldering.
But the RTC is dead anyway and it would be a shame to lose the motherboard.
Reply 24 of 64, by myne
Low melt is plenty. No need to go too nuts.
I built:
Reply 25 of 64, by multiplebaboons
If after looking at the pics the consensus is still low-melt solder, I can order that.
Reply 26 of 64, by multiplebaboons
shevalier wrote on 2025-07-30, 12:00:
The plan was to fix the chip, I got the sockets , batteries, battery holders etc. 😉 I actually don't see how i could damage the chip if I very gently tried to pry with a screwdriver like you suggested. I am almost positive that all but two pins are free.
Reply 27 of 64, by jakethompson1
I wish I had responded earlier. I use an "Engineer" hand solder sucker to remove these. I have never had luck with anything else, including braid or power suckers. It is imperative that it is kept cleaned out of solder inside and, after cleaning, the inside walls need to be kept lubricated.
Reply 28 of 64, by multiplebaboons
I've seen this on youtube and I don't think my skill level will permit this. The wire will probably just fall off...
Reply 29 of 64, by multiplebaboons
jakethompson1 wrote on 2025-07-30, 20:10:
This is what I used, seems like a knockoff of your tool and it was very useful, I only used the wick on a few pins: https://www.amazon.com/dp/B0CFTGBV79
Reply 30 of 64, by jakethompson1
multiplebaboons wrote on 2025-07-30, 20:16:
I'm confident it can still be repaired. Here is one I did using that tool that isn't pretty on the underside (possibly applied too much heat) but works perfectly after putting a socket in.
Also: if you haven't already run into this, you can add fresh solder to the pins that won't wiggle, then melt it and use the tool again. Fresh solder will flow better. You should be able to try a handful of times before you damage the via.
By the way, the DS12C887A+ is still made and in the US, you can buy a legitimate one from DigiKey or Mouser for $13.
Reply 31 of 64, by myne
https://www.ebay.com/itm/152857370714?_skw=lo … %3ABFBMnNHw2Ytm
I built:
Reply 33 of 64, by myne
https://www.microcenter.com/product/659408/sr … er-paste-053-oz
I built:
Reply 34 of 64, by multiplebaboons
myne wrote on 2025-07-31, 01:03:
I am officially an idiot, because that thing was right in front of me and I bought something else. No matter. After reflowing those two pins once again and finally realizing that my $6.99 iron is garbage (I hoped it'd be good for one use) and then very carefully prying the chip, it boinked out in a snap. Here I only cleaned the flux a bit. Any thoughts on whether I need to mess with the traces, or do i just go ahead and solder in the socket?
Reply 35 of 64, by myne
It's unlikely you did more then scratch the coating off.
They weren't that delicate back then.
Multimeter will confirm.
I built:
Reply 36 of 64, by multiplebaboons
myne wrote on 2025-07-31, 02:20:
Which is yet again something i don't own... A good one would be over a hundred bucks, no?
Reply 37 of 64, by myne
You don't need a good one.
Hell, for this an led, battery and 2 wires would do.
I built:
Reply 38 of 64, by shevalier
multiplebaboons wrote on 2025-07-30, 20:09:
nwX287
Why are you so fixated on this Dallas?
For $20, they sell replacement modules everywhere, along with the battery and socket.
When choosing between a motherboard and a IC, it's worth sacrificing the IC.
P.S. If Dallas doesn't come back to life, you can easily find links to nwX287 yourself.
Reply 39 of 64, by multiplebaboons
shevalier wrote on 2025-07-31, 05:05:
Not anymore. 😉 Once it became clear that things weren't going exactly according to plan, I essentially followed your advice -- it just so happened that I was much closer than I thought and the rtc chip came off right away.
