RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3060 of 3072, by sharangad
RaVeN-05 wrote on 2025-07-31, 06:30:
almost perfectly Rabel Moon rendered.
Some very little noticeable minor graphical glitches left.
Thanks @Raven-05, will fix them.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3061 of 3072, by sharangad
Bugs 003 happens on original hardware and it looks to be an z-buffering bug or lack of. I would post a video, but my capture dongle doesn't go any lower than 640x480 .
Reply 3062 of 3072, by sharangad
And the final one. Sorry about these being JPEGs. I attached them to the post instead of linking against my server.
The other two will be fixed.
Reply 3063 of 3072, by sharangad
Rebel Moon Fixes (hopefully final):
https://nirvtek.com/downloads/RReady.Alpha.20 … 01.RebelMoon.7z
MD5: 2632214aa3080804262a57d459aa4997
- This *should* correct all outstanding Rebel Moon chroma keying bugs and perhaps not introduce new ones.
- There is a problem with the keyboard input sometimes not responding in the dosbox window after existing a Speedy3D game. Pressing [ALT] fixes this. This will be fixed .
[EDIT]Attaching PNG images to the forums produces cel-shaded low bitrate attachments. So here are links instead. So here are JPGs/[/EDIT]
[EDIT]At some point I should put up a video on how this was fixed[/EDIT]
Reply 3066 of 3072, by sharangad
A brief overview of how the Rebel Moon bugs were fixed using screen space derivatives is available here:
https://www.patreon.com/posts/overview-of-moo … ntent=join_link
and
https://youtu.be/vH-zlu9VKT0
Reply 3067 of 3072, by sharangad
ICR2: I've increased the base memory used by the game to its limit of 64 MB. The texture heap is a separate 256 MB. I think there's still some sort of internal partitioning going on, which stops the extra memory from being used.
By restricting Dosbox's RAM to 16 MB I got this:
V:\CR>cart
DOS/32A -- Protected Mode Run-time Version 7.35
Copyright (C) Supernar Systems, Ltd. 1996-2005
Sierra On-Line, Inc.
Version 1.0.2-RN1 Build #61
DMA Memory fragmentation:
Pointer buf :
Command buf :
Digital Sound
Port 220 IRQ 7 DMA 1
Conf irmed with SB16 8 ST
Memory Check: 584000 LO 13602800 HI 14186800 ALL
Insufficient memory. Free up 69013168 bytes, and try again
V:\CR>mem
632 Kb free conventional memory
63 Kb free upper memory in 1 blocks (largest UMB 63 Kb)
14912 Kb free extended memory
14912 Kb free expanded memory
This is with a 256 MB texture heap. It's complaining about the *other* memory (other than the texture heap).
69013168 = 69 MB. This version of the game needs 256 MB alone for the heap, so this has to mean it's complaining about everything else. Usually the entire game needs just 16 MB, with 6 MB for the texture heap and 10 MB for the rest. I *think* if I can unpartition the thing to use mroe RAM, textures would just work.
https://nirvtek.com/downloads/ICR2.64MB.OtherMemory.001.7z
MD5: 4ed3bc2eb1973c8809031bf9c3e7aae8
(This link is fairly useless, since the game behaves exactly the same, but I need it preserved in case of catastrophic hard drive and backup failures).
Reply 3071 of 3072, by sharangad
RaVeN-05 wrote on 2025-08-02, 16:15:
tested Rebel Moon, its perfect now! =)
Thanks a lot for all the testing!
I have another build:
https://nirvtek.com/downloads/RReady.Alpha.20250802.004.7z
MD5: c32b89f0ac8c80bad0708b90b031ef6b
which should allow vquake to run on your laptop (dual core).
You'll need to set
threadsafe=false
highperformance=true
picdma=true
override2core=false
ICR2 should be full speed again. I don't know if the games will be stable without major lockups. I've been spending some each day trying to reduce the cpu load of the whole process. Custom carsets in ICR2 probably won't be possible. This will force a bunch of settings if you the CPU has fewer than 3 cores. Enforced thread prioritization has been disabled. So the possibility of hiccups and slowdowns even on quad or better systems is higher, even when dual core settings aren't enforced.
[EDIT] On some systems (Haswell Pentium 3 GHz Intel HD graphics) threadsafe=true, picdma=false, highperformance=-true and override2core=true works really well for ICR2, but not vquake. On my Ryzen 2700X in dual core mode the Haswell settings are terrible. It works much better with the first bunch of settings under the download link.
Reply 3072 of 3072, by sharangad
This is looking like the next release candidate:
- vQuake cvars d_dither and d_bilerp should work correctly
- Rebel Moon all chroma keying bugs should be fixed.
- ICR2 [ALT+B] (autobrake) should function correctly.
- Formula 1 RRedline performance boost (including for everything using paletted textures).
- Improved dual core performance in a default config. (Needs more testing). The minimum required GPU (Intel HD4000) should perform better on the minimum CPU dual core 3 GHz (Haswell).
I think it's better to do incremental updates instead of massive ones with lots of fixes. It's a lot easier to test and isolate problems.
[EDIT]
Or with the same optimization extended to quad cores and beyond:
https://nirvtek.com/downloads/RReady.Alpha.20250803.001.7z
MD5: 031f0bd95305993dc4cd34cd97218f09
I really need to rebuild my Sandy Bridge HD2000 based machine. Motherboards are available, but i don't know whether the CPU still works. The i7 2600 still sells for quite a bit.
[/EDIT]
[EDIT2]
Detroit Belle Isle (2004-1995, 2/4 of these are regurgitated), Detroit Downtown HQ (new) and Houston:
https://youtu.be/yOmgm3wNZXk
[/EDIT2]
