First post, by Rafael Oliveira
Rafael Oliveira
Offline
Windows 1.0 Says Setup Is Not Able To Create The Directory You Specified Please Specify Other Directory But l Selected C:/WINDOWS Windows 1.0 Alpha General Failure Reading Drive B DR5 Doesn't Copy The Files (Insufficient Disk Space) But l Have Enough Space On The MS-DOS VM And MSWIN Does Bad Command Or File Name
