First post, by Rafael Oliveira
Windows 1.0 Says Setup Is Not Able To Create The Directory You Specified Please Specify Other Directory But l Selected C:/WINDOWS Windows 1.0 Alpha General Failure Reading Drive B DR5 Doesn't Copy The Files (Insufficient Disk Space) But l Have Enough Space On The MS-DOS VM And MSWIN Does Bad Command Or File Name
Reply 1 of 4, by Rafael Oliveira
How Can l Fix This Problem Please Help l Googled And l Find Results For Windows 10 But This Isn't Windows 10!
Reply 2 of 4, by Rafael Oliveira
l Saw Someone Posting The Same Problem On Beta Archive But With Windows 1.0 DR5 And Didn't Resolved
Reply 3 of 4, by Rafael Oliveira
Update Alpha Says Disk Is Full ?
