DOOM 3 v/s Windows 11
First post, by Speedwarrior956
Warrior reporting....
....on a major squabble i'm having trying to install such a legendary game into my "war machine". (See the attached screenshots for context.)
For starters, the installer -it uses the infamously pesky Windows Installer thingy rather than the more ubiquitous InstallShield Suite- throws a file deletion request....without it being installed!
(It actually did it on both localized distributions of the game.)
Then, after playing with the InstallShield pack's settings , I've been able to run it in maintenance mode, where it thinks i'm reinstalling it.... on my external HDD!
....and then, i kept on editing said settings until it, #Finally, decided to get to work....except that it requested to install said game on a "network" drive, only to end up insalling it on my "Games" repository. Partially, that is.
(D:\Activision\ID Software\Doom 3)
BTW, here i'm including said setup settings for further scrutiny.
Are there any other sugguedtions on how to install this on Win11? #PleaseHelp
Reply 1 of 2, by The Serpent Rider
Is this purely for academical reason? Because you can transfer Doom 3 from any old OS without installation.
Reply 2 of 2, by darry
Maybe something is getting lost in translation, but why is the installer trying to create a "DOOM 3 server image" ?
Are you running the right installer ? Are you using original install media or the GOG release ?
The attachment Screenshot_20250808-130807-486.png is no longer available
