HWiNFO for DOS resurrected !
Reply 900 of 938, by Mumak
Grzyb wrote on 2025-01-01, 17:40:
My Celeron still pretends to be a Pentium II...
I have uploaded version 6.2.6. Please let me know if it fixes the problem.
Reply 901 of 938, by Grzyb
Mumak wrote on 2025-01-01, 20:27:
Looks OK now...
The attachment 625.png is no longer available
The attachment 626.png is no longer available
Nie rzucim ziemi, skąd nasz root!
Reply 902 of 938, by Mumak
Thanks for the feedback.
Reply 903 of 938, by zuldan
HWiNFO for DOS thinks my AWE64 Gold is a PAS.
The attachment IMG_20250308_113846.jpg is no longer available
Reply 904 of 938, by feipoa
Has there been any thought to adding a BIOS image copy feature to HWINFO? If you do implement it, an option to save as EVEN/ODD (two file) could be helpful for some people.
Reply 905 of 938, by Mumak
zuldan wrote on 2025-03-08, 01:41:
Can you provide the HWiNFO Debug File so I can check it?
Reply 906 of 938, by Mumak
feipoa wrote on 2025-03-08, 01:53:
In the past HWiNFO was shipped with small utils to dump some data including BIOS image (but not even/odd). They can be downloaded now here: https://www.hwinfo.com/files/old/
Reply 907 of 938, by zuldan
Mumak wrote on 2025-03-08, 07:39:
Managed to spend some more time on this. It's a very strange bug.
I ran HWiNFO today and it worked perfectly, BUT...
The attachment AWE64.jpg is no longer available
I then closed the app and ran it again but this time I got the Microsoft Sound System.
The attachment MSSound.jpg is no longer available
Here is the debug file for when it detected the Microsoft Sound System.
The attachment HWINFO.zip is no longer available
It's a bit tricky to replicate. I can't do it everytime but when the bug does occur, I go into Mainboard info then Video info and finally Peripherals info. Let me know if you need anything else.
Reply 908 of 938, by Dusko
Hi, I've been using HWiNFO for as long as I can remember, and I'm really happy it's still being maintained!
That said, I just wanted to report a small bug: HWiNFO reports the Sound Blaster 16 DSP version as 4.4, when it should actually be 4.04.
Retro PC games channel: https://www.youtube.com/@myOldPC-75
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reply 909 of 938, by Mumak
Dusko wrote on 2025-08-08, 03:38:
Thanks, will be fixed in the next version.
Reply 910 of 938, by DarthSun
HWinfo DOS. RyZen+7900GS+SBLive / Native DOS run.
The attachment HWi_1.jpg is no longer available
The attachment HWi_2.jpg is no longer available
The attachment HWi_3.jpg is no longer available
The attachment HWi_4.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 911 of 938, by Mumak
The DOS version is not designed for such later systems. It intentionally lacks support of these systems to maintain a low footprint.
Reply 912 of 938, by DarthSun
Mumak wrote on 2025-08-08, 11:41:
Of course, I know, I just added it as an interesting fact that it can detect a few things well even from this.
Reply 913 of 938, by Grzyb
It would be nice to provide clear statement about recommended versions for various hardware categories.
Something like:
"for 16-bit CPU - use HWiNFO16
for 32-bit CPU - use HWiNFO for DOS
for 64-bit CPU - use HWiNFO for Windows"
Reply 914 of 938, by Mumak
There's no eaxct margin where to use HWiNFO for DOS or HWiNFO32. I'd say:
For 16-bit CPU (8086-286) - Use HWiNFO16
For 32-bit CPU (386+) - Use HWiNFO for DOS; for systems capable running W2k/XP use HWiNFO32 for Windows
For 64-bit CPU - Use HWiNFO64 for Windows
For ARM64 (Windows) - Use HWiNFO ARM64
Reply 915 of 938, by DarthSun
It runs fine under Win98 on the 7.02 madness machine.
The attachment hwiandsandra.jpg is no longer available
Reply 916 of 938, by Mumak
Yes, HWiNFO32 supports Win98 too but you'll usually get better results under Win2k/XP
Reply 917 of 938, by DarthSun
Yes, a great program!
I have a mania for running the older operating system on the latest computer, which is why I like that it runs on Win98 as well.
Reply 918 of 938, by ruthan
Mumak wrote on 2025-03-08, 07:42:
Well it would be nice incomporate it Gui menu, it would be nice to add Videobios dumping too, because its need for Linux KVM vios part through and Linux versio is problematic.
Newer system and memory footprint, its solvable with better management.. you can probably split data and load and unload them on the fly one by one during detection, its not actually rocket science.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 919 of 938, by CkRtech
Attempting to get video info on a Diamond Viper VLB results in graphics corruption that changes to different-looking corruption after exiting the application and executing other apps with various video modes. Power cycled to fix.
X-vesa seemed to work ok.
I wonder if it has to do with the Viper using an Oak chip for vga compatibility and a Weiktek P9000 for the VESA modes. Something similar happens when running a pre-version 6 of univbe on my system.
Example of screen after selecting video info while inside hwinfo:
