Reply 100 of 188, by Yoghoo
- Oldbie
mkarcher wrote on 2025-08-14, 18:37:Yoghoo wrote on 2025-08-14, 18:02:Other tools like Astra and NSSI report only 384Kb XMS and 4Mb EMS. The 384Kb is probably the real memory from this PC (which has 1Mb memory and 4Mb EMS).
The sounds like you might have HIMEM loaded, an XMS driver for your "real XMS". I recommend you to try without HIMEM first. It's quite possible that EXMS86 is incompatible with another XMS driver at the same time. Not loading HIMEM also means you can not put DOS into the HMA ("DOS=HIGH"), so this will cause less conventional memory being free.
No himem.sys is loaded. If loaded (I tried 😀) it will not load and gives a warning.
