EXMS86 (XMS for your 8086)
Reply 100 of 112, by Yoghoo
mkarcher wrote on Yesterday, 18:37:
Yoghoo wrote on Yesterday, 18:02:
Other tools like Astra and NSSI report only 384Kb XMS and 4Mb EMS. The 384Kb is probably the real memory from this PC (which has 1Mb memory and 4Mb EMS).
The sounds like you might have HIMEM loaded, an XMS driver for your "real XMS". I recommend you to try without HIMEM first. It's quite possible that EXMS86 is incompatible with another XMS driver at the same time. Not loading HIMEM also means you can not put DOS into the HMA ("DOS=HIGH"), so this will cause less conventional memory being free.
No himem.sys is loaded. If loaded (I tried 😀) it will not load and gives a warning.
Reply 101 of 112, by Sneakernets
I will be testing the beta soon, but overnight with some playlist of midi files playing on DOSMID, I got a "Error: Memory Access Fault". I replayed the midi that was playing separately, and no crash. Interesting. Perhaps it is related to the issue in the post before mine?
Reply 102 of 112, by mateusz.viste
EXMS86 refuses to load if it sees another provider of XMS memory.
Yoghoo wrote on Yesterday, 18:42:
This beta works a lot better. Mem is working. CheckIt Pro and Norton System Information 8.0 don't hang or crash anymore. They both show 4MB EMS and 4MB XMS. NSSI shows 320KB XMS 2.0 and 4MB EMS. Astra shows no extra memory above 1MB.
Wolfenstein 3D still hangs after a short time.
That's good news, I'm glad to hear. Astra is probably using the XMS3 API, which is unsupported by EXMS86. The NSSI case is much stranger. What version of NSSI are you using? I will try to reproduce the issue on my side with the same version.
Same question about Wolfenstein - is it one of the "normal" versions, or some fork?
http://mateusz.fr
Reply 103 of 112, by Yoghoo
mateusz.viste wrote on Yesterday, 18:50:
NSSI version 0.60.45. Wolfenstein 3D is the normal full version. The exact version I don't know but it's not the GOG version (which includes Spear of Destiny).
Reply 104 of 112, by mateusz.viste
I confirm the strange NSSI report. What happens is that NSSI does not rely on the XMS API to get the *total* of XMS memory, because the XMS API simply does not have such function. The XMS API can only provide the amount of currently available memory.
NSSI itself allocates XMS buffers for its own use. Then it calls the XMS API to get the available memory, and then it surely calls several int 15h functions to get the total. Afterwards it must do some math to compute the total, used and free and it certainly gets confused along the way since int 15h knows nothing about EXMS86, and vice-versa, so the math has no chance to add up.
I don't see any reasonable solution here. I mean, the only solution I think of is to intercept int 15 and answer to queries AH=88h, AH=C7h, AX=DA88h and AX=E820h instead of letting the BIOS answer, but this becomes quite a contraption. I'm afraid that might lead to some side effects, plus of course it would considerably increase EXMS86 resident size. I don't think it's worth it since the issue will likely appear only with some specialized diagnostic programs, not "normal" applications.
http://mateusz.fr
Reply 105 of 112, by wierd_w
Intercepting int15h in a compact way to change reported size already has an example implementation in the syslinux project, in the memdisk component.
It (memdisk) hooks int13 and int15, to present a ram backed block device over int13, and adjusts output of int15 so the guest OS does not walk on the ramdisk's allocation.
It's not a dropin, of course, but their code weighs in at around 5k, iirc.
Reply 106 of 112, by mateusz.viste
wierd_w wrote on Yesterday, 20:22:
EXMS86 has a resident footprint of 800 bytes, for comparison.
Yoghoo wrote on Yesterday, 19:05:
I tested with the shareware version 1.4, no issues. It uses XMS quite intensively, but everything seems stable. You mentioned that it has "both lines maxed out for XMS and EMS." - it's strange because in my test Wolf3D allocates all the EMS at start, and then when it asks for XMS there is none left. The difference on your side is perhaps due to the larger EMS card.. I can only emulate a 2MB card with 86box. I wonder if Wolf3D tries to use both EMS and XMS at the same time when it sees both available. In theory it should not be a problem, but who knows.
As a test, could you try loading EXMS86 with the "!" argument and see if it improves Wolf3D stability? With "!" there will be no EMS advertised, so the game will be forced to use exclusively XMS.
http://mateusz.fr
Reply 107 of 112, by mateusz.viste
also tested the shareware 1.1 version - works flawlessly on XMS (with "EXMS86 !"). With just "EXMS86" (no "!") it also works perfectly, but then again on my VM Wolf3D does not detect any XMS available and hence uses only EMS. I'm afraid I'm getting to the limits of what I can do with my virtual testbed.
http://mateusz.fr
Reply 108 of 112, by Sneakernets
Would it be best if we had a tinytest program for this? Not asking for the world, but something that copies some memory around, and see if things stay sane.
Reply 109 of 112, by mateusz.viste
EXMS86 v0.9.6 released today. Changelog:
  • new arg '3': pretends XMS 3.0, fools apps that check for but do not need it
  • fixed XMS-to-XMS transfers that cross 16K boundaries
  • non-implemented functions return a proper error code
  • optimized odd-length transfers (kindly suggested by mkarcher on vogons)
  • lots of minor size and speed optimizations
http://mateusz.fr
Reply 110 of 112, by mateusz.viste
Sneakernets wrote on Yesterday, 21:38:
Here is the test program I wrote to stress EXMS86.
http://mateusz.fr
Reply 111 of 112, by Yoghoo
mateusz.viste wrote on Yesterday, 20:53:
Will try tomorrow. Nice to see you're so actively busy with this project btw. 😀
Reply 112 of 112, by Sneakernets
mateusz.viste wrote on Yesterday, 21:42:
hooray! looks like my XT passed all the tests. This is good!
