Reply 20 of 24, by nickles rust
I've made a small amount of progress. I downloaded the T2 linux install image for 586 (K6-2 is not 686?) and I can boot this in a DVD drive. I also finally found a PCI SATA card that is recognized. I can then boot the DVD, and install linux to the SATA drive. But then I can't get to the SATA drive again. I can boot the DVD and mount/access the SATA drive that way (as if I were installing all over again), but the BIOS can't boot the SATA drive directly.
So I think I need a mini-linux install on a CF card or something that the BIOS can boot, which in turn can boot the SATA drive. I think there is only a single thread here on this forum about linux, so does anyone know where I can go to find this sort of info?
