Reply 20 of 23, by Decrypt
DaveDDS wrote on 2025-08-13, 15:14:I've been working on/mostly finished a little tool which might be of use: […]
Floppy Disk Recover
use: FDR <drive>: file[.FDR] [options]
opts: -L Low density
-N New
-M force Monochrome
-?F show Format of .FDR
-?I "" Interactive keys
-R Review .FDR (no updaate)) FDR file.FDR
-I Convert .FDR to raw .IMG "" "" outfile
FDR can help recover diskette sectors which fail "normal" reads, but may be
read with minor drive alignment adjustments or other treaks.
It will auto-read the entire disk, show the read-status of the tracks/sectors,
then let you manually seek, select and try reading individual "" as
you "tweak" the drive.
Regretable I'm travelling at the moment, and won't be able to properly update
my site for about a week - if you need it sooner, we could find a way to get
it to you.
This sounds interesting but there's no rush, whenever you can it's fine. Cheers!
