Reply 60 of 138, by Raldsen
Archer57 wrote on 2025-08-21, 13:11:
That's why i dislike hot chipsets, yes. Also AFAIK all NF4 are defective, but i may be wrong - there is no definitive information on what's defective and what is not.
I don't know where you are getting this from? But if it's still running great after 20 years its obviously not defective.
Yes, on modern hardware, not sure/have not tested how it'll work on this old stuff given CPU and other parts of the system do play a role here. It is also completely irrelevant for a storage drive.
My A8N SLI deluxe isn't that new, in fact it predates yours by almost a year. Same chipset minus the southbridge. I attached a screenshot of crystaldiskmark with the pcie 1.0 @ 1x drive benchmark.
Well, i'll test what the temperatures are on specific system. So far from what i've seen in this case airflow is good enough for things to not become too hot as long as no 500W GPUs are used.
Also number of fans + meshes does not equal good cooling. Often the opposite. The airflow has to work in a sensible way, like front intake back exhaust. It does in this case. When cases are made of mesh almost entirely with stupid number of fans - there is no directional airflow at all - just a bunch of fans blowing in random directions.
This board will deteriorate though, nothing i can do about that. It gets too hot to hold just laying around on a table...
Just get a slight breeze in the case, I made my nForce4 chipset with a Zalman ZM-NB47J heatsink go from barely touchable for 5 seconds to pleasantly lukewarm with just one of those cheap aliexpress pci bracket coolers running at 5v.
I'll probably find something different eventually. Perhaps something based on K8T890. I prefer simpler boards anyway and this one is more suitable for a bench, fooling around with SLI and everything, than for a permanent build.
That's a good board yeah.
Reply 61 of 138, by Archer57
Raldsen wrote on 2025-08-21, 15:27:
Well, i got 3 8800GTs for this build which are absolutely 100% defective and are still working after all the years also. As well as some AGP stuff like 7600GT and 7800GS. Bumpgate is not a death sentence, if conditions are right affected hardware can last.
Does not matter ultimately, if i am wrong and it is not defective - that's great.
Just out of curiosity i've popped in JMB585 + (slightly full) 860pro and it works like this:
The attachment sata3.PNG is no longer available
35MB/S random 4k are not impressive for pci-e at all...
But yeah, this only shows that free pci-e x4 can be useful. Hmm, may be i should leave this card in here instead of using buggy onboard SATA which works as SATA1 only with modern drives...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 62 of 138, by Archer57
So i've ran 3dmark05 game benchmarks with "repeat each test 5 times", got this temperatures (i am using this tool in aida simply to get statistics, did not run tests themselves):
The attachment temper.jpg is no longer available
I do not see anything horrible here, judging by HDD temperature inside the case does increase by a few C, but that's to be expected and i'll leave it like this. Also i did not notice significant/noticeable performance drop with cool&quiet enabled, it does drop both frequency and voltage so i'll leave it on for now.
Reply 63 of 138, by AlexZ
How long is 5x in 3d mark 05? I wonder if something like 30 minutes is sufficiently relevant. The case must be closed as it would normally be, in the location where it is supposed to be. The worry is basically in warm days like when ambient temperature reaches 26-28'C and the system is running for at least an hour it could start to overheat. Probably more relevant temperature is motherboard rather than hard drive. A hard drive can be easily replaced although the data will be lost.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 64 of 138, by Archer57
AlexZ wrote on 2025-08-21, 17:38:
Yeah, it'll be around 30 minutes or so. But it is abnormally high load, would not be like that in actual games. May be a longer run would be more precise, but honestly - i am not a fan of stress tests, i'll try to run aida in background when i actually play something and see how it goes.
Ambient is around 26.
The reason i am looking at HDD - it is not used/does not generate much heat (this is secondary storage, OS is on SSD, and it is 2.5 inch HDD) and is useful as "ambient inside the case" sensor. Not because i am worried about its longevity. "Motherboard" sensor... not sure what it is measuring but it constantly stays between 40 and 50 regardless of extra cooling, motherboard laying on a table or inside the case, etc. Looks like unreliable data.
Videocard also has "board" and "ambient" sensors, but those very obviously measure board temperature, when the board heats up they both go up even in the open.
Reply 65 of 138, by AlexZ
Temperatures look good. That motherboard sensor could be chipset temperature, VRM or somewhere close to pcie slot. You would have to check value just after booting.
My Athlon 64 3400+ is in case Zalman Z9 Plus. After 10x run of 3d mark 2005 (about 1.5h to complete), with 27.5'C ambient temperature, the maximum temperatures were:
- CPU - 50'C (38-41'C when idle, without cool&quiet, 1300 rpm)
- GPU - 64'C (47'C when idle, 1250 rpm at 35%, custom fan profile set in BIOS)
- Samsung 860 EVO - 28'C
- Western Digital 1TB magnetic HDD - 42'C (located in internal aluminum HDD box with little cooling fan removed).
Reply 66 of 138, by Living
Archer57 wrote on 2025-08-15, 18:08:
By the way i absolutely love the place they've chosen for that red sata port...
that is Aopen Ax59pro FDD port level of dumb
Reply 67 of 138, by Archer57
AlexZ wrote on 2025-08-21, 19:39:
Temperatures look good. That motherboard sensor could be chipset temperature, VRM or somewhere close to pcie slot. You would hav […]
What's curious - i've started aida right after boot, yet it shows minimum of 45C... not sure where the sensor is, but it is weird.
But yeah, temperatures look fine to me so far, of course i'll have to see how it works over time, but i suspect it'll be fine. This system will likely use <200W under load which is nothing by modern standards and that 120MM fan does have much better performance than typical optional 80MM fans in beige boxes from late 90s early 00s many of this systems would have ended up in.
Sadly i can not see SSD temperature because my aliexpress special SSD has fixed 40C readout.
Z9+ is a good case, i would not hesitate using it for a modern system with 1000W PSU "recommended", in fact it is probably better than many modern cases. It is large though, as many of those cases are. I want small and stackable, which is one reason for my choice...
Living wrote on 2025-08-22, 02:43:
That one is even more crazy 😁
Many weird decision on those older boards, especially during transition from AT to ATX, but later too. Even modern boards still have annoying layout issues from time to time, but nothing so crazy.
At least i can kind on see why asus did this - they wanted esata on the back io panel and probably did not want to route the traces through whole board, so they placed the chip along with the second port next to the back panel...
Reply 68 of 138, by PD2JK
totally off topic
Hah! Right now I'm conducting some benchmarks with this board. I disabled the floppy, screw that.
has all kinds of stuff
Reply 69 of 138, by Raldsen
Archer57 wrote on 2025-08-21, 15:49:
It's very typical for all SSD's, even the average unraided consumer NVMe's at PCIe 4.0 or even 5.0 only usually does about double that. Even your SATA3 SSD only did 13MB/s more. I did a benchmark on my MSI K9A2 Platinum system and compare the SATA2 speeds with my previous benchmark. Now you see that a NVMe even at PCIe 1.0@1x is quite a bit snappier than a SATA2 SSD.
Reply 70 of 138, by Archer57
Raldsen wrote on 2025-08-23, 11:18:
Yeah, and that's sad. All this SSDs are marketed as "better, faster" but in reality they are progressing backwards. Many NVME SSDs, even 4.0 or 5.0 can be slower than good SATA SSDs, especially if the load is heavy enough. Ultimately performance depends on SSD itself (controller, flash, etc) and PC, not the interface.
And that's easily visible by comparing your pci-e x4 results to my sata3. Though 860pro probably is the fastest sata ssd ever made, and sadly they are not sold anymore. That's why i am not a fan of buying cheap nvme stuff - it is not practically any better.
I generally expect at least something like this from NVME, this is, at this point, old 3.0 x4 SSD on LGA2011 workstation:
The attachment nvme.PNG is no longer available
You are making me curious though, i'll probably try something decent on this hardware and see how well it works.
Reply 71 of 138, by Archer57
So, here we go...
Being crazy person that i am i decided that after all the time spent making this stuff work properly second system deserves being built too:
The attachment sound_video_ssd_D.jpg is no longer available
The attachment motherboard_D.jpg is no longer available
The attachment case1_D.jpg is no longer available
The attachment case2_D.jpg is no longer available
I have all the hardware anyway (and still have a few of this case + PSU kits), even if i am not going to use both systems at the same time storing it like this, in functional condition, makes sense.
I do not have second 4800+ CPU, so this one is 4200+ Manchester instead, again 2 gigs of RAM (hmm, i am running out of suitable 1GB sticks...), HD3850 AGP and audigy4. Along with SF-2281 SSD i spent a couple of evenings rebuilding firmware for, which can be switched to sata1 mode and works with VT8237R perfectly.
The only complication - i do not have anything to use for storage, ancient 40GB IDE drives make no sense here and newer sata2-3 stuff does not work.
I'll post aida screenshots for both systems a bit later...
Also one more bug i discovered in this hardware while building it - if i put soundcard in the last slot weird stuff happens - the sound does not work properly and one CPU core is constantly at 100% load. This stuff is fun...
Reply 72 of 138, by AlexZ
If you have a spare case then why not. Athlon 64 X2 4200+ is a good basis for comparison with Athlon XP 3200+, same clock speed, same cache. Maybe you can disable one core somehow for exact comparison. It's probably best to delegate Athlon XP to Windows 98 and have this for Windows XP. It should be ok for any Windows XP era game (2002-2006) as long as you don't need 1920x1080. 1920x1080 was historically Windows Vista/7 era.
Probably the last pci slot is damaged. You can try putting a video card there to find out.
I'm waiting with my AM2+ build for Zalman Z9 U3 case. If I don't get it within 2 weeks I will probably use Cooler Master N500 that I already have (https://www.newegg.com/cooler-master-atx-mid- … N82E16811119280). Zalman Z9 is a sturdier case than N500. Historically, these cases were used for FX Vishera. Zalman Z9 U3 has a floppy slot and GPU length limit 290mm so it's more suitable for AM2+. N500 could be used for modern PC. PNY GTX 780 OC is unfortunately 296 mm long and I will have to cut off 6mm from the card to fit in. It is possible without damaging the card but I'm not sure if I want to make such a destructive modification. Alternatively, I could fall back to Gigabyte Windforce GTX 770 or MSI Gaming G4 980 (non Ti, which should be about as fast as PNY, I got it specifically because it is shorter). There is also GeForce GTX 680 on sale locally but the owner wants $57 which is too much and it's a founders edition which is not a great choice as they run hot.
Reply 73 of 138, by Archer57
AlexZ wrote on 2025-08-23, 19:42:
Yeah, i've bought 5 of this cases and power supplies some time ago, there were some crazy discounts and they ended up ~$50 for a case+PSU. This cases are not adequate for really hot hardware, but 200-300W are totally fine, which works for a lot of stuff. Turns out a single 120mm exhaust fan + some holes in front of the case can make a massive difference and beat vast majority of period correct cases.
Hmm, interesting. May be i'll play around with it. So far i've compared 4800+ with 4200+ and even if 4200+ is overclocked to the same ~2.4Ghz (which is really easy without touching the voltage and may be i'll do it) there is still ~10% difference in stuff like 3dmark.
I still need to compile and post the benchmarks i've ran on this board with 4800+ and some AGP cards, some of those are quite interesting even though i already see i did not do everything exactly right and i am certainly not going to redo it.
Perhaps. It is visually fine though and the card is detected, drivers work, it just causes abnormal CPU load once the drivers are installed and sound is glitchy. Feels more like incompatibility or resource conflict of some sort.
There is also a mention of post cards not working in this slot on the retroweb.
Yeah, for that kind of cards the choice of cases makes sense. Are not this extreme overkill for the platform though?
Funnily enough for the cases i am using manufacturer claims up to 320mm videocard and 330mm total length (no drive bays...), i have not measured it though and even i would not put GTX780 or something into one, unless the card itself exhausts hot air out of the case.
Also cutting the card does not sound like a good idea IMO. I'd be more likely to rip out the drive cage from the case if i had to do something like this...
I've also been trying to find a cheap S939 CPU, like 3200+-3500+ venice or something, purely for testing purposes and may be to compare with S462 (i have the second board like this) but so far - no luck. Seems like nobody is selling them at all. I've found 4000+ san diego for ~$50, but not going to grab that as i do not really have a use for it...
Reply 74 of 138, by Raldsen
Archer57 wrote on 2025-08-23, 12:40:
It's very impressive for a consumer SSD, better than the 970 EVO I used in that PCIe2.0 x4 benchmark.
Me too 🤣, that's gotta be something enterprise grade like an Optane.
But if you want less buggy SATA, why not ditch both Nvidia and VIA for 939 and go for something with an ULi or ATi southbridge. Like the MSI RX480 Neo2-F or MSI RD480 Neo2. I got an ASRock 939Dual-SATA2 which has been spotless with SATA SSD's, but very bad caps, like a bad cap festival with every shit brand present.
Reply 75 of 138, by Archer57
Raldsen wrote on 2025-08-24, 00:49:
That's an option, but IIRC early ATI SBs had serious issues with both USB and SATA performance. Which leaves ULI, which i would like to have, but it is not easy to track down.
But having pci-e which does not interfere with videocard, like on A8N32-SLI Deluxe, gives an option of using a decent pci-e sata controller instead. So i guess that's an advantage for this motherboard.
On A8V all that's possible is either IDE-SATA, SATA1 with SF-2281 SSD or PCI-SATA, all of which have very similar performance.
I did find a very curious motherboard during my search - A8V-X. That's the same K8T800 Pro as on A8V, but paired with much newer SB - VT8251, which provides SATA2 and a couple of pci-e x1 slots. May be i'll get this one, if nothing else AGP + pci-e x1 is a curiosity.
Reply 76 of 138, by Archer57
So... that SSD did not last very long. Apparently it was a hardware issue after all. Had to use IDE-SATA again for now, at least it works and $10 aliexpress SSDs are reliable. I'll probably try to find something decent for both systems, like intel 520 or something, but that is not going to be fast as i am definitely not going to pay what people are asking for this.
Here are the specs for the systems i ended up building:
The attachment S939-PCIe.jpg is no longer available
The attachment S939-AGP.jpg is no longer available
Could not resist playing around with overclocking slower CPU a bit, not sure if i'll leave it like that or not but given the cooler is more than sufficient and i never touched the voltage i do not think there is any risk here.
Reply 77 of 138, by Repo Man11
I have an A8V - X. A local computer store had NOS for sale (IIRC it was $50.00), and since I already had some 939 CPUs... Though it lacks any voltage controls, with same CPU and memory as my Gigabyte GA-K8U I was able to overclock everything at stock voltage to almost the exact same performance. It's nice that I can use a PCIe X-Fi card with it. I think these scores were with a slight overclock, later on I had it scoring slightly higher than the K8U but I don't have any screenshots.
Reply 78 of 138, by AlexZ
Your memory clock is too low, watch DRAM memory divisor.
Reply 79 of 138, by Archer57
Repo Man11 wrote on 2025-08-24, 15:01:
Well, my results for systems above are this:
AGP:
The attachment 2001-1024.jpg is no longer available
The attachment 2003-1024.jpg is no longer available
PCI-e:
As i said earlier - surprisingly similar.
Also curious that A8V-X has no voltage controls, because A8V has, even more/better than much fancier A8N32-SLI Deluxe. Asus is weird.
AlexZ wrote on 2025-08-24, 15:19:
Well, with this platform it is impossible to get exactly what you'd want. It is either low, or too high. I either need better memory which'll work at ~450, or have to be content with what i got here.
So far from what i am seeing here is that the same memory which worked on nforce2/s462 at 400/2.5/3/3/7 and could OC by at least 10% up to 440 with the same timings with no issues barely works at 400/3/3/3/8 on S939 and will not handle even the slightest OC. And i thought nforce2 had quirky memory controller...
