Reply 60 of 138, by Raldsen
Archer57 wrote on 2025-08-21, 13:11:That's why i dislike hot chipsets, yes. Also AFAIK all NF4 are defective, but i may be wrong - there is no definitive information on what's defective and what is not.
I don't know where you are getting this from? But if it's still running great after 20 years its obviously not defective.
Archer57 wrote on 2025-08-21, 13:11:Yes, on modern hardware, not sure/have not tested how it'll work on this old stuff given CPU and other parts of the system do play a role here. It is also completely irrelevant for a storage drive.
My A8N SLI deluxe isn't that new, in fact it predates yours by almost a year. Same chipset minus the southbridge. I attached a screenshot of crystaldiskmark with the pcie 1.0 @ 1x drive benchmark.
Archer57 wrote on 2025-08-21, 13:11:Well, i'll test what the temperatures are on specific system. So far from what i've seen in this case airflow is good enough for things to not become too hot as long as no 500W GPUs are used.
Also number of fans + meshes does not equal good cooling. Often the opposite. The airflow has to work in a sensible way, like front intake back exhaust. It does in this case. When cases are made of mesh almost entirely with stupid number of fans - there is no directional airflow at all - just a bunch of fans blowing in random directions.
This board will deteriorate though, nothing i can do about that. It gets too hot to hold just laying around on a table...
Just get a slight breeze in the case, I made my nForce4 chipset with a Zalman ZM-NB47J heatsink go from barely touchable for 5 seconds to pleasantly lukewarm with just one of those cheap aliexpress pci bracket coolers running at 5v.
Archer57 wrote on 2025-08-21, 13:11:I'll probably find something different eventually. Perhaps something based on K8T890. I prefer simpler boards anyway and this one is more suitable for a bench, fooling around with SLI and everything, than for a permanent build.
That's a good board yeah.
