First post, by Famicom
Hi Dege,
First of all, thank you for your incredible work on dgVoodoo2. I’m currently using it on Sega Rally 2 (PC, 1999), and it’s working beautifully — except for one specific issue related to multiplayer menus.
The problem:
In the multiplayer section, the game has several menus where the player must type their name, or search/create/join a game. These input fields do not show any text when typing. The keyboard works (you can press Enter and proceed), but the content isn't rendered. Running the game in Windows 98 compatibility mode solves the issue: the text appears. But as expected, other things stop working: music, ReShade, etc.
So the issue seems tied to how standard Win32 text controls are rendered in this specific screens of the multi-player mode — possibly using GDI or USER32 drawing paths that are broken under DirectX emulation? Is there any setting or workaround you’re aware of that could make dgVoodoo preserve those Win32 edit box renderings? Or is it a known limitation when emulating DX6/DDraw pipelines?
Any insight would be very valuable — and again, thank you for your dedication to preserving and enhancing classic games.
Reply 1 of 6, by Squall Leonhart
the input fields are GDI and require the GDI systemhook on the extended property tabs, right click on the dgvoodoo cpl window to expose them.
Reply 2 of 6, by Famicom
Squall Leonhart wrote on 2025-08-07, 22:52:
I tried enabling the GDI system hook in the extended options as you suggested, but unfortunately it didn’t solve the problem — the input fields in the multiplayer menus are still invisible when typing. Maybe it's something else dgvoodoo can't hook to?
Reply 3 of 6, by ELK
Famicom wrote on 2025-08-08, 07:08:
Are you sure ReShade isn't the issue?
Reply 4 of 6, by Famicom
ELK wrote on 2025-08-14, 06:05:
100% sure ReShade has nothing to do. It happens with and without ReShade being even installed.
Reply 5 of 6, by davidmorom
Instead of using the whole Windows 9x compatibility mode, which usually causes more trouble than it fixes, use the Application Compatibility Toolkit to create an entry for "SEGA RALLY 2.exe" and enable only the shim "EmulateTextColor". You'll probably want to enable also "HardwareAudioMixer" to prevent the volume of the game to mute itself.
Reply 6 of 6, by Famicom
davidmorom wrote on 2025-08-21, 12:48:
Thank you.
This totally fixed it. I was hoping dgVoodoo's GDI hook to take care of it, but this is the next best thing and it just works 😀
