The Serpent Rider wrote on Yesterday, 10:29:
Ark 2000 was an obscure budget chip which just so happened to nail VGA and Mode X (supposedly), when it was already mostly irrelevant. All cards I saw with this chip were only 2 Mb too.
Also apparently only Ark 2000MT has EDO memory, although it doesn't indicate performance outright, like I've outlined with superclocked Trio64 supporting only FPM.
I only use dos+win3.1, then all my test are in DOS, but even in windows 95, the difference is brutal. For example, emulators like Gens in pentium 200 are much faster than using the fastest S3 Virge i have, same happen neoragex, with virge i need to use 11khz and some frameskip, with ark i can even go to 22khz without frameskipping
The only card i have is fast like ark2000 is a riva128 but this one is agp
One thing, ark2000 with 1mb is much slower than 2mb, i read than 1mb = 32bit, 2mb 0 64 = bits
