Reply 20 of 27, by DustyShinigami
- l33t
Oh. One thing I am confused about are the pins. I'm struggling to decipher where each placement is. Especially as I've read that if I'm using a twist floppy cable, it needs to be set to MO...? There are currently two jumpers. One, I'm guessing, is set to SO by default...? The other looks to be at JA and JB, but I'm guessing those are set to Ground...?
I just want to make sure things are set correctly. Especially as I'll be getting a physical floppy drive to go with it and that I would like as the Master and the Gotek as the Slave.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
