Reply 80 of 138, by Repo Man11
I actually flashed an A8V BIOS to my A8V-X hoping it would work (since the boards are incredibly similar) to get the voltage controls, but it wouldn't POST with that BIOS so I had to go back to the stock one.
Reply 81 of 138, by AlexZ
Archer57 wrote on 2025-08-24, 15:39:
Well, with this platform it is impossible to get exactly what you'd want. It is either low, or too high. I either need better memory which'll work at ~450, or have to be content with what i got here.
So far from what i am seeing here is that the same memory which worked on nforce2/s462 at 400/2.5/3/3/7 and could OC by at least 10% up to 440 with the same timings with no issues barely works at 400/3/3/3/8 on S939 and will not handle even the slightest OC. And i thought nforce2 had quirky memory controller...
You may need to increase latency, but the board probably doesn't allow to select higher than 3. AMD memory controller is not as good as NVidia's. On my s754 Athlon 64 I run DDR400 (2x1GB) with timings 2.5-3-3-8 though.
There existed 1GB DDR500 stick A-DATA Extreme Edition Vitesta. DDR500 - 3-4-4-8, DDR400 - 2.5-4-4-8. It is supposed to be a kit of 2x1GB.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 82 of 138, by Archer57
AlexZ wrote on 2025-08-24, 17:51:
I can increase timings, but it does not help. It really, really does not like going above 400. May be different memory would help, may be it would not. All those faster kits are basically just binned and overclocked, nothing officially rated higher than 400 exists, AFAIK. Also the sticks i am using are technically 400/3/3/3/8, so the fact they at least work at nominal settings is good already.
If i want to OC i have to drop the divider one step though, no way around it. Because of how it works it ends up being something like 315 too, instead of 333. I could try dropping CPU multiplier a bit (it is possible) and increasing base frequency further to raise memory and HT closer to nominal values, but that requires further experimentation - there are a lot of variables to fool around with.
As pictured it is still noticeably faster than with nominal 2.2Ghz CPU, 1Ghz HT and 400 memory...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 83 of 138, by AlexZ
You need to find a way to activate DRAM divisor 12. You are running with 14. 2400mhz with divisor 12 leads to ddr400, your nominal ddr speed. It will be an indirect setting as you probably have DDR speed in BIOS setup just like AM2, not multiplier. It was also influenced by HT multiplier in AM2. Try increasing base frequency while lowering CPU multiplier to keep frequency the same.
Reply 84 of 138, by Archer57
AlexZ wrote on 2025-08-24, 19:18:
It is configured a little differently here - i can choose divisor in relation to "FSB" in BIOS, so it is 1:1 for 200, or 5:4 for 166 (which obviously ends up being 160). There are no options in between, so i have to set it to 5:4, which means i need to set "FSB" to 250 for RAM to be 200. It works out the same way with HT too. So theoretically i should be able to then set CPU multiplier to 10 and get nice and round 2500 (CPU can do that), but... it does not work. Does not even post past ~240 FSB, even with very low multiplier, so it is not the CPU - it is the motherboard. PCI/AGP frequencies can be set separately so it is not that, but i suspect something is getting overclocked and does not like it...
Reply 85 of 138, by Archer57
Tried actually using the system a bit... and i can say i am quite happy with it. I was able to run a few things that have issues on later cards and comparing things side by side with 7600GT - finally see improvements in how AA/AF works on GF8 compared to GF7. Temperatures are fine, noise is great...
Downsides:
Had to swap out X-fi card for another audigy4, though it initially seemed that everything was working fine - issues with nforce4 PCI + X-fi were there and quite annoying. It is curious how creative blamed nvidia, yet audigy works just fine in the same conditions...
SSD is randomly detected as SATA150 or SATA300. Does not seem to affect things too much, but i do not like this. Going to replace it with Intel520 i was finally able to find...
Working with this hardware is... interesting. It is horribly, unbelievably buggy. Practically nothing works as it should. I can only imagine the frustration bumping into bugs like this back in the day when all the stuff was expensive and it was not possible to just try a few cards and see what works better, like it is now. Did not have so much issues/bugs even on earlier stuff, like on S462 everything pretty much just worked, apart from nforce2 memory issues....
Reply 86 of 138, by AlexZ
Archer57 wrote on 2025-08-24, 20:36:
Interesting. My Gigabyte GA-K8NE has a setting called "CPU/DDR clock Ratio" with options 2/1, 2/1.33, 2/1.5, 2/1.66, 2/1.83, 2/2. I can configure DDR speed very precisely. Manual doesn't list many options in MB Intelligent Tweaker but BIOS does have them.
Archer57 wrote on 2025-08-27, 13:22:
That's bad luck. I use Sound Blaster Audigy 2 ZS.
Reply 87 of 138, by Archer57
AlexZ wrote on 2025-08-27, 14:44:
Not really bad luck. This was to be expected. I would not have got x-fi card at all if i initially expected to use this motherboard. This was a common issue and one i've seen back when this hardware was new too. Creative blamed nvidia, nvidia said nothing, there were some talks about driver or bios fixes and also reports of the same issues on non-nforce boards...
I do have Audigy 2 ZS, it is a nice card, but relatively uncommon, pricey and also compatible with W98, so i've used it in W98 build...
This audigy4 cards are much less fancy, basically a cheap version, but they still do everything they need to. The only reason i wanted x-fi card is to try those few games which support EAX5 and this build seemed fast enough for that, but... well, may be i'll stick it into LGA775 system i have, though i'll have to somehow bypass the issue of onboard NIC being dead and only one PCI being available. Or may be i'll use it in the second, AGP, s939 system...
Ideal solution would be getting pci-e x-fi titanium, that would allow me to use SLI too if i wanted (PCI card makes that impossible), but i can not find one locally which is not like $500. Will be one more thing on the list of stuff to look for...
Reply 88 of 138, by agent_x007
As far as I know, on K8 CPUs RAM speed is always based on CPU frequency divided with limited integer values (ie. 12, 10, 8, etc.).
Because there is no direct link between HT Link base and DRAM clock base - you can't have a "nice" fractional multipliers, and CPUs with .5 or odd multipliers will create issues for at least one of "stock" RAM speeds (stock = 400/333/266 by default).
Example of mess it can create : https://hosting.photobucket.com/albums/r306/C … 1337/DDR2_2.jpg
On all K8 CPUs during OC, you always have to take check :
1) HyperTrasport (too fast will make board unstable, going for 600 or 800 speed is fine if 1000 can't be attained) [CPU<=>NB].
2) Chipset link (chipsets for AMD K8 like to utilize seperate HyperTransport for linking north and south bridges together (so called "NB<=>SB"), which may require the same adjustment as "CPU<=>NB" link when overclocking usual base HT link speed (some boards allow bit width selection on this connection too).
Reply 89 of 138, by Archer57
agent_x007 wrote on 2025-08-27, 22:41:
As far as I know, on K8 CPUs RAM speed is always based on CPU frequency divided with limited integer values (ie. 12, 10, 8, etc. […]
Yes, RAM speed is often "messy" with this CPUs, but... apart from not looking nice i doubt something like 315 would make a huge difference compared to 333.
Also on this specific board (asus a8v) is seems like "via v-link" used between NB and SB may be causing stability issues with higher base clock values because it seemingly gets overclocked and there seems to be no way to prevent it. HT and memory multipliers can be changed, PCI/AGP can be set to 33/66, but there is nothing regarding NB-SB link in the bios...
Ultimately does not matter all that much because i doubt slightly slower memory would make too big of a difference...
Reply 90 of 138, by AlexZ
RAM speed is messy but some motherboards have more options than others. Locally, there is Gigabyte GA-K8N-SLI on sale (of no use to me as I have no s939 cpus). I have checked the manual and it has the same "CPU/DDR clock Ratio" options like mine - 2/1, 2/1.33, 2/1.5, 2/1.66, 2/1.83, 2/2. This setting somehow influences the DRAM divisor you are talking about. DRAM divisor is dynamic, when the CPU clocks down due to cool&quiet the DRAM divisor is lowered.
You can also workaround the lower DRAM speed by OCing the CPU a little bit. 100-200Mhz is usually possible without needing voltage adjustment.
nForce4 is probably more stable than VIA as there is just one chip. My Gigabyte GA-K8NE could go to 250 base clock, I haven't tested higher values.
I will be using Cooler Master N500 case for my AM2+ build.
Reply 91 of 138, by Archer57
AlexZ wrote on 2025-08-28, 14:56:
Single chip unless it is "SLI X16". Then it is the usual single chip paired with a northbridge for extra pci-e. Everything connected with HT as far as i understand.
And this is, IMO, a good reason to avoid "SLI X16" variant altogether. Something i did not know before doing this build.
Reply 92 of 138, by AlexZ
Gigabyte GA-K8N-SLI is also listed as 2x PCIe x16. There is nothing in the manual about dropping to x8 mode in SLI, but it probably happens without 2nd chip. It is a single chip board but also has a socket for some kind of SLI card between pcie slots. Position of pcie slot prevents installation of fan on chipset cooler and pcie x16 slots are too close for more powerful GPUs. Also 2 SATA ports would be blocked by GPU. It seems it is max for 2x GeForce 9800 GT or 250 GTS.
Yeah your ASUS A8N32-SLI Deluxe is Nvidia nForce4 SLI X16 unfortunately. Gigabyte GA-K8N-SLI is plain SLI.
Reply 93 of 138, by Archer57
AlexZ wrote on 2025-08-28, 15:37:
Yeah, sadly this are very common board layout screw-ups, some of them like sata blocked by videocard are still there on new boards too.
At least on the board i have the slots are far enough from each other to realistically use 2 dual slot cards and there is even an x4 slot above top x16, so technically a soundcard can be added. So i guess at least layout can be considered an advantage here. SATA is still blocked by the card in top slot though, at least partly.
Theoretically it is possible to use pci-e switch to get 2*x16, one of those used on dual chip cards like HD3870x2. I am honestly surprised they did not do this instead of adding whole northbridge for this purpose. There were later boards, even on LGA1155 and such, which did this.
But in case of S939 whole idea is kind of pointless anyway - 2*x8 would be more than enough for any cards realistically feasible with this hardware and i am not even sure HT bandwidths is sufficient to support full 2*x16...
I did not really choose this board, it was bundled as a bonus with the CPU so i had no choice here. I have been looking for this CPU for far to long to not get it. It has its disadvantages but it works for now, may be i'll replace it eventually, may be i'll stick with it. Depends on if it cooks itself to death and if i find something i like. Too many boards, like that GA-K8N-SLI you've mentioned, with plenty of their own downsides...
Reply 94 of 138, by luk1999
Make sure that HT Link multi is set to 4x, you might also try lower multis (default is 5x).
If your motherboard has options like "Read Preamble" and "Max Async Latency", you might also try to play with them. They might help with higher HTTs.
P4 3.4E, P4C800-E Dlx, 1 GB, X800 PRO 256 MB, SB Audigy, XP SP2
A1.4, A7V133, 512 MB, R8500LE, FM801, ME
P3 600, AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
K6/266, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
Reply 95 of 138, by Repo Man11
Another note on the A8V-X - I got it back out, and rediscovered something I had forgotten. With a Patriot Burst 120 gig SSD you can't use the SATA port; it will be detected, it will format, and the install of WinXP will proceed, but it will eventually halt with one form or another of blue screen. I'm pretty sure this same thing happened when I tried a Samsung SSD a couple of years ago. With the Patriot drive attached to an IDE port with a SATA adapter, the drive speed is very poor (around 40 MB/s), but that's an inexpensive drive with firmware that probably doesn't like being attached to such an old controller. Using the same memory, CPU, and video card as my Gigabyte GA-K8U the performance is too close to call even though the Gigabyte board has voltage options for both the CPU and the memory.
Reply 96 of 138, by Archer57
Repo Man11 wrote on 2025-08-31, 23:41:
So via never fixed their sata, it still does not work one way or another? Would not be surprised...
Should not be that slow using ide-sata though, i've used this adapters with plenty of various SSDs, old or new, and they tend to be only slightly slower than sata1 - ~100-110MB/s. Perhaps it is limited to UDMA33 because it thinks that cable is not 80 conductor or something, i've seen that...
Reply 97 of 138, by Repo Man11
Archer57 wrote on 2025-09-01, 08:10:
The same drive on the same adapter has done considerably better (over twice as fast) on much older boards than this, so there is a bug. I encountered this on a Socket 775 chipset - the inexpensive SSD I used didn't like the SATA 3.0 controller and it dropped it down to about SATA 1.5 speeds (might have been this same brand of drive). I tried a Samsung and the issue was cured.
The Samsung drive I'm using with the Gigabyte board peaks at about 130 MB/s measured with ATTO.
I just found the thread, it was a TeamGroup SSD drive in that case, and the Patriot drive was the better one. P5Q Pro Turbo SATA port in SATA 1 mode with Windows XP
Reply 98 of 138, by Repo Man11
I just dusted of my Asus A8V-XE (K8T890) for some testing. With a Silicon Power A55 SSD, a 4200+ etc. I get about 130 MB/S write and 160 MB/s read as measured with ATTO, no issues at all.
I switched to the Opteron 180, the same memory, and a GTS250. Similar to the A8V-X, this board has no options for increasing the voltage on the memory or the CPU, but I was able to push the FSB to 218 with no issue. With the increased FSB the drive speed increased to 170 write and 138 read as measure by CrystalDiskMark. 3d 2001 score is 34,648, 3d 03 is 37,446. Next up will be the A8N-SLI.
Reply 99 of 138, by pentiumspeed
Silicon Power in USB sticks and their SSDs is one of rare quality stuff for a third party stuff.
Cheers,
Great Northern aka Canada.
